IKEA Gainclone
Hallo everybody, here is my IKEA LM3875 Gainclone.
Quick notes:
• Case: Ikea Lack shelf, cut and emptied of the inside cardboard ( please see my previous Densenclone [ http://www.diyaudio.com/forums/class-d/220995-densenclone.html ] experience and picture 1 ) and aluminum sheet to cool the IC’s ( quite enough for home listenings, after 3 hours of playing it’s only slightly warm )
• IC: LM3875
• Power supply: 2 x 24V – 200VA transformers
• PCB from Audiosector
• Star ground to avoid hum noise
• 2 single 12 position make-before-break rotary switches, connected to various resistances ( ground, 10, 22, 39, 82, 180, 330, 680, 1.5K, 3.3K, 4.7K, 8.2K ) to obtain the input 20 Kohm stepped attenuator
I’m quite satisfied of its sound ( and power … ) and my wife of its aesthetics.
Ciao.
Luca
TQWT speakers ( off topic ... )
Hi Jjrh,
here are the internal measures of the speakers. Use 19 mm MDF.
Any 17 - 18 cm ( or 6 - 7 in ) full range speaker will fit, from Tang Band to Fostex.
Since painting MDF with good results is not easy, I covered them with matt white vynil adhesive sheets.
Ciao.
Luca
Heat issues
Hi Bare,
I know that TA2020 amp quite well: it was me who made it !! It's the Densenclone.
With 12 Vcc power supply there are no cooling problems at all, just like the famous Sonic Impact T-Amp.
The LM3875 needs more attention, as You said, and before choosing this case I made some tests in order to see if the aluminum plate was enough or some heatsinks were necessary.
After hours of playing ( at home volume, for stadium volumes I cannot tell ... ) I saw that the plate was only slightly warm, so no heatsinks. Anyway, for better cooling, I made 2 holes in the bottom plate and 2 holes in the backplate ( please see pictures ) to let the fresh air pass by.
Ciao.
Luca
Power Supply rearrangement
Hi everybody,
here is an upgrade of the power supply wooden case: I had to screen it inside with kitchen aluminum sheets, as when it was very close to the amp I heard a little hissing coming from the speakers ( that’s why the original Gaincard uses metal boxes … ).
Now the noise is over and I can put them close. You can see them in the new arrangement ( with the speakers in rest position ).
Ciao.
Luca
