Old 5th February 2004, 06:37 PM   #11
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by geolemon
This application note seems to indicate that this parallelling technique can be used to increase the power level seemingly without limit, and/or to create chip amps that are low-impedance compatable.
Opinions?
Mister, you ask a lot. I suggest that you start right away to build something!
You have one real limitation and that is the max supply voltage. +- 42 volts isn't particulary much. But if you have 0.5 ohms load you can get some LM3886 and get real much power out.
/Per-Anders (my first name) or P-A as my friends call me
Old 5th February 2004, 07:56 PM   #12
indoubt is offline indoubt  Netherlands
indoubt's Avatar
STK442-130
Sanyo 2 x 150 Watt LF eindversterker module
http://www.bmm-electronics.nl/Produc...roduct_ID=1647
and for less than 17€
Don't know how that sounds though
Or:
STK4050V
Sanyo 200 Watt LF eindversterker module
€ 22.89 excl. BTW
edit: think about bridging these
better be indoubt untill you're sure
Old 9th February 2004, 01:46 PM   #13
miguel2 is offline miguel2  Portugal
I am thinking in using OPA541s for a subwoofer amp. With the National datasheet and using the LM3886 as model, it says we can squeeze 150w from 2 parallel chips into 4 ohms.
Miguel
powerful Chip - audio digital amplifier olzon Chip Amps 1 14th November 2008 07:25 PM
Is LM3875 chip waterproof? Peter Daniel Chip Amps 236 19th January 2006 04:56 PM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
I'm looking for LM3875 chip??? thomgun_lc Chip Amps 5 3rd January 2006 07:26 AM
Page generated in 0.06769 seconds (73.62% PHP - 26.38% MySQL) with 11 queries
