| Chip Amps Amplifiers based on integrated circuits |
Hi everyone!!
Could someone please tell me what the max. level of DC offset from a source (in my instance a CD player) can be before the DC input cap is really necessary in the Gainclone? Usign my multi-metre I put one probe inside the phono socket of my cd player, and the other touching the outside of the socket, with the player on, but no CD. measured about 0.54mv on both sockets. Is this acceptable, or should I use the 4.7uF input cap? Thank you, - John. P.S. Nuuk i have read the section on DC offset on your site, but this is with a built Gainclone. I onyl want to build my gainclone once, so need to have the circuit/parts worked out before building. Cheers. |
#2 |
Seems ok, you'll probably get an additional 10-20mV at the output of the amp which is quite acceptable IMO.
#3 | |
#4 |
Connect your source to the amp (with speakers disconnected and CD in PLAY) and then measure it on the amp. If it's less than 80mV (or so) it should be fine.
#5 |
Thanks for all the advice guys! So - if I've understood this correctly - in order to measure DC offset properly the CD player MUST be connected to an amp, and must also be playing a CD then? can I not just measure the DC directly from the phono sockets on the CD player?
#6 |
it is possilbe because the player has some DC out...if it's low then u don't need a DC blocking cap in front...however with an amp...the voltage will rise...due to gain and of course the opamp itself itself will have a little Offset...so you have to test for offset at the outputs as well to determine if your amp is working properly...but you wun need the DC blocking capacitor (usually 4.7uF) in front as your CD player seems to have low offset...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#7 |
Hmmm.... I think I'll go without the input cap then. I'll just make damn sure to test it with an old pair of speakers first
I doubt - when all's said and done - that there can be a day and night difference between using either the cap, or the input resistor instead. when I've saved up more money I'll build a second one and try it with the input cap and compare the sound. So I gues it comes down to what sounds best - a 220r 2w carbon film resistor, or a 4.7uF Black Gate non-polar cap... |
#8 |
dont forget that the amplifier will amplify the offset of your cd player
| Lissajous figures | rtarbell | Everything Else | 1 | 28th October 2005 01:23 AM |
| Noise Figures | northsiderap | Solid State | 12 | 7th May 2005 08:48 AM |
| Xmax figures to actual exurcsions? | TRANSDUCEReng | Subwoofers | 20 | 21st September 2004 08:19 PM |
| Distortion figures for analog muxes | eplpwr | Parts | 32 | 4th June 2003 03:23 PM |
| help, need some figures | Alex_B | Multi-Way | 54 | 9th December 2002 12:36 AM |
