Old 3rd February 2004, 11:59 AM   #1
FredG is offline FredG  France
Default Resistor value in the feedback loop
I'm currently listen a NIGC with a combination of 25K (MK132) + 750R (RC55) for the feedback loop.
Previously, I was listening with 14.7K (RC55) + 442R. (RC55). The sound is much more natural now, with a :lot of details but less involving than before.
Did someone listen to different combination of resistors values in the feedback loop, leading to the same gain ? Is it better to use 15k or 25K in the feedback loop ?
FredG.
Old 3rd February 2004, 08:36 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
You can change the sound of the Gainclone (IGC or NIGC) by experimenting with resistor values and the arrangements for reducing DC offset.
In my own experience, reducing DC offset can result in more detail but the music is somehow less involving.
The answer to your question lies in your own experiments!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 3rd February 2004, 09:41 PM   #3
GregGC is offline GregGC  Canada
Default Re: Resistor value in the feedback loop
FredG.
Do you have a cap in the Feedback network (in ser to 442R)? If you do, the smaller the value of this res. the less the low frecuencyes will be amplified. In that case I'd opt for larger values of the res. so that the cap has relatively lower value.
Can you show us the sch. you use?
/Greg
Old 4th February 2004, 09:31 AM   #4
Nuuk,
For the moment, I think the not so involving (but fully transparent) sound comes from the MK132 and not from the value itself. I’m perhaps wrong. I just put this resistor in the amp and I’m waiting a few days to carefully listen to it. But the first listening session is often relevant.
GregCG,
No, I’m not using any cap in conjunction with the 750R. The offsets are about 20 mV and 29 mV.
Here’s the schema I’m currently using :
FredG.
Old 4th February 2004, 12:03 PM   #5
loong is offline loong  United Kingdom
I experienced with a NIGC: 22K + 680, with 20K pot and C 2.2UF (SCR), 35+35V, with (1000+1000+10) UF per rail. All register are normal metal oxide film. It's really good!
Old 4th February 2004, 01:06 PM   #6
I don't say that with caddocks the sound is not good, but the music lacks. With this shema, I tried different resistors and all of them have their own sound... MK132 is really famous among audiophiles and I'm a bit puzzled by the result I have.
Old 4th February 2004, 06:00 PM   #7
PauSim is offline PauSim  Portugal
PauSim's Avatar
Default resistor value in feedback loop
Hi FredG
I saw an on-line commercial version featuring 180k/10k/22uF63V in the feedback loop plus a 1k in series/1M/1uF63Vin series/22k to +in.
Most people (myself included) is using 22k/680 because it´s close to what is stated in the NS specsheet and the original GC (LM3875) circuitry.
Given this disparity of values for the feedback resistors, seems like the combinations are endless.
Me, I think I´ll try the Final Labs approach, to apply a variable resistor (not a panel pot though, but a trimmer soldered right next to to the IC´s pins) to fine-tune the loop.
Being an insane tweaker .:3 with KEIN degree in Electronics
(mind), here´s what I´ll do: connect 47k trimmer pin 3 to LM1875 pin 4, trimmer pin 2 to IC pin 2, trimmer pin 1 to ground; maybe small value resistor offsetting trimmer, from IC pin 4 in series with trimmer pin 3. Haven´t a clue if it will work at all.
I´m not advising you to try it, just my 2c. Opinions are welcome as usual, both pos or negs.
Bonne chance!
Paulo
Old 6th February 2004, 12:37 PM   #8
macboy is offline macboy  Canada
FredG,
Your schematic seems very strange. The 25K in series with the input followed by a 1K to ground makes a voltage divider which attenuates the input signal by -28 dB. Why are you doing that?
Old 6th February 2004, 01:53 PM   #9
Originally posted by macboy
FredG,
Good observation. Change the 1K res to gnd with 25k and you'll luse only 6dB instead of 27dB.
Old 6th February 2004, 02:13 PM   #10
25k + 1k is my fixed pot ! It fixes the level I listen. I don't have any pre, just the output of the CD player and the NIGC. I don't want to introduce a pot when i'm trying to listen to resistors...
FredG
Resistor values in feedback loop/voltage divider??? vynuhl.addict Solid State 29 13th February 2007 02:05 PM
feedback loop rmenger Instruments and Amps 4 21st October 2006 07:04 PM
feedback loop rmenger Parts 0 29th July 2004 01:24 PM
Using a variable resistor in the feedback loop. darren01 Chip Amps 9 30th December 2003 10:05 AM
Feedback Loop help KevinLee Solid State 4 1st December 2002 01:39 AM
Page generated in 0.15495 seconds (63.75% PHP - 36.25% MySQL) with 10 queries
