Make things clear about PSU
Old 3rd February 2004, 03:30 AM   #1
Guss is offline Guss  Canada
Guss's Avatar
Default Make things clear about PSU
Hi there, a few questions here...
Tell me if I am right or wrong so far...
Primaries and secondaries are just two diferent output values of the transfo, right? Can both be used to acomodate diferent circuit at the same time?
If I want to run say a couple of leds together with my LM3875, I wire my amp in parallel with my leds and I lower the voltage with diodes and series resists, right?
Ok now some more technical, could you explain or refer me somewhere I could read about the way a diode works ?
Oh yeah almost forgot the rails, rails are only the designed output to work with?
Thats all...for the moment :P
Goss
Old 3rd February 2004, 04:18 AM   #2
theChris is offline theChris
primary attaches to the AC from the power company, secondary to the user circuitry.
rails are supposed to be the maximum voltages in the system.
diodes have an exponential V - I curve, often approximated as a straight line. -- at 10mA the diode may drop 0.7V. at 100mA 0.71V at 1A 0.73V, at 1000A 0.8V, ect... so pretty much if your using led's you assume a voltage drop of whatever (find out how much voltage drop there is by using a series resistor and finding a current). for some diodes it is 0.7V, for schockty diodes it is usually 0.3V. this also varies with temperature. in anycase you estimate a voltage drop across the diodes, then use a resistor to limit current where (Vsource - Vdiodes)/Idiodes = R.
hook a diode up backwards and it will not conduct, well, they will if you put a lot of voltage across it.
never attach a diode across a source without some method of current limiting, it will drop about 1V and otherwise act as a short.
if only it could be used for good, not evil...
Old 3rd February 2004, 05:47 AM   #3
GregGC is offline GregGC  Canada
Default Re: Make things clear about PSU
Goss
Try this link.
http://www.epanorama.net/links/basics.html
Old 3rd February 2004, 07:18 AM   #4
Jennice is offline Jennice  Denmark
Hi Guss,
Maybe you'll find this pdf file interesting:
http://www.sylvest.dyndns.dk/Notes_o...oad%20file.pdf
Best Regards,
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 3rd February 2004, 12:13 PM   #5
Guss's Avatar
Well, thanks for the replies, got a lot more reading ahead if I want to make this gainclone I dream of :P
Make things clear about PSUHide this!Advertise here!
Clear acrylic speakers - any ideas? (Also, how should I make B3s open baffles?) Spasticteapot Full Range 17 22nd October 2006 05:19 PM
Three things you can do to make CD players sound better Jocko Homo Digital Source 227 26th February 2006 11:27 AM
Things that make you drool karma Everything Else 31 22nd April 2003 11:06 AM
Copyright ©1999-2017 diyAudio
