Question about bridging TDA 7293 - diyAudio
Old 2nd February 2004, 10:44 PM   #1
Cro maniac's Avatar
Send a message via Skype™ to Cro maniac
Question Question about bridging TDA 7293
I am planning to build a car amplifier with TDA 7293. For supply I used schematic of SMPS from ESP.
I was wondering if TDA 7293's can be used in modular aplications with more than 3 devices. (4 or 5 for example). Has anyone done it?
I saw that few people have made amps with 3 TDA 7293 (1 master & 2 slave devices).
Does anyone of you good people knows how much undistorted power I can get from 3 TDA 7293 on 4 ohms with +-36V supply ?
Thank You all in advance for any answer given !
Old 3rd February 2004, 06:18 PM   #2
quekky is offline quekky  Singapore
quekky's Avatar
Default Re: Question about bridging TDA 7293
lots of, estimate it to more than 100W at low distortion
the problem with more than 3 ICs is it's not easy to do the routing, even with double-layer pcb
Old 3rd February 2004, 08:19 PM   #3
Cro maniac's Avatar
Except the problem with routing, is there any other known problem with doing >3 chips in parallel ?
I saw that You have just finished amplifier with 3 TDA 7293 in parallel. It looks very nice. Is it capable of driving 2 ohm impedance (with how much power on the output ?) ?
For my project, I would need at least 200W on 4 ohms with little distortion, with possibility of driving 2ohms (with more power on 2 ohms than on 4). How many devices do I need to parallel for that ?
Could You advise me which project would be acceptable for my needs, and, is there maybe an easy way to calculate (predict)output power with known number of chips in parallel ?
Old 5th February 2004, 04:58 PM   #4
quekky's Avatar
http://www.stereophile.com/amplifica...63/index7.html
Fig 16 should give u a rough idea
Old 6th February 2004, 10:10 PM   #5
Cro maniac's Avatar
Thank You !
That link was very helpful.
Question about Bridging eeyore Tubes / Valves 7 30th October 2008 08:30 AM
Amp bridging and performance question augerpro Solid State 10 15th June 2008 07:45 PM
Adcom GFA-545 II bridging question dhoover Solid State 4 30th August 2006 11:17 PM
An odd bridging question Musher Solid State 4 17th June 2002 04:50 PM
Bridging question PassFan Tubes / Valves 2 5th June 2002 06:04 AM
Copyright 1999-2017 diyAudio
