LM3886 Kit Comparison
and the non linear effect of adjacent metal to the coil (singular).
The coil also emits radiation and that radiation can affect loop areas of the amplifier.
This is the main reason I keep the output inductor away from the amplifier board.
BTW,
the Network that Neville Thiele came up with was a combination of capacitor from Hot output to Cold return AND an inductor in the feed from amp output to speaker terminals. If you read Dr Cherry's short article on the Thiele Network you will see many of the variations that can be made to work, especially if one adopts an intermediate value along the continuum for which N.Thiele only defines the end values.
The Thiele Network is both the Zobel AND the inductor.
