Speakers for Chip amp - diyAudio
Old 8th April 2015, 07:15 PM   #1
atomik7 is offline atomik7  United Kingdom
Default Speakers for Chip amp
OK I am a beginner at the bottom of what looks like a steep learning curve and I need steering in the right direction.
I cant recall how this all started but I ended up building a “Non-Inverting LM3886 Stereo” chipamp which has since been put into daily service playing dab radio and music stored on an ipod. My musical tastes are rock biased but I appreciate all sorts of stuff.
I am really pleased with the amp but less so with the floorstanders I am using.
I don’t think I am in the same listening league as a lot of folk on this forum but I like things to sound good and I am fairly certain my speakers let things down.
I read that chipamps do well with full range speakers so I looked at frugalhorns pensils and fonkens and then I read full range aint so good with rock and that I will probably find them lacking bass.
Then I read about F.A.S.T. and decided I like the Tysen – it looks more complicated than the frugalhorns but I thought if it gives me what I am after so be it. Then I read they were bi amped…… then I thought do I need to build another amp …...Then I thought I should have built a different amp…..Then I thought should I build a multi way speaker…... Then I looked at transmission line designs…. Then my head started to hurt …..And now…… Well I just don’t know any more.
I am going to stick with the amp and I like the size and shape of those slopey Tysens but I just don’t know if they will be suitable or even possible with my amp.
What should I do? Any help would be greatly appreciated
Old 8th April 2015, 08:12 PM   #2
Hi, What floorstanders ? rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 9th April 2015, 12:25 AM   #3
Also how big is your room and where can the speakers go?
If you can get them right into the room corners, Bibs do well for bass and are a "simple" build https://speakerprojects.wordpress.co...-loudspeakers/
John
http://www.decdun.me.uk/ Decibel Dungeon http://sound.westhost.com/ Elliot Sound Proucts ESP http://www.allaboutcircuits.com/ All About Circuits
Old 9th April 2015, 01:29 AM   #4
nigelwright7557's Avatar
fane do some good full range speakers.
Fane Sovereign 200LT are good, I put a pair in a cabinet and they sound good.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Old 9th April 2015, 07:49 AM   #5
jacques antoine's Avatar
Really?
From specs: "Usable Frequency range -6db: 45hz-10khz"
Old 9th April 2015, 05:40 PM   #6
Hi Sreten: I was afraid someone was going to as that. The speakers are long abused eltax symphony 6. My other half exploded the caps in them one drunken evening so they were replaced with something the same value but considerably bigger in size. I also replaced the tweeters with some by Morel but for the life of me I can't remember what model they were.
Hi John: the room is 6m x 5m with a vaulted ceiling 3.1 m high. I am stuck with position. if you stand facing the 6m wall one speaker is in the corner on your right. to the left of the speaker there is a sideboard on which the amp stands. to the left side of the sideboard stands the other speaker they are approx 2m apart. I checked out your link those bibs are big she who must be obeyed will never agree to those
Thanks to all for the replies so far.
Old 9th April 2015, 06:03 PM   #7
When they are done cover them in matching wall paper and they will blend in lovely, honest
Old 9th April 2015, 06:10 PM   #8
Or try for a pair of Metronomes, elegance itself
The Metronome
Old 9th April 2015, 09:00 PM   #9
6x5 room with 3+ meter hight?
bad luck there.
for that i would propose some big floorstanders.
most probably would go with something 3 way that has 10 inch woofer...
alternative would be a pair of smaller speaker (2 way, 6.5" woofer max. and minimum 4") and least 1 subwoofer with 10-12 inch driver.
if You don't feel that funky, you might re-invent the wheel and make a pair of decent 3 way speakers. probably it would be way out of question for sheer size. isobaric setup comes to my mind, at the expense of more drivers you can cut them down in br. space to about 2/3 of the original-
but that is about it. no way out.
for a medium size room like that to have reasonable level of bass, you need something that can move enough air. raw power is not that important, i bet you can get away with anything remotely close to 2x20 watts RMS.
V*A=VA
V*A*PowerFactor = WATT
Old 10th April 2015, 05:41 AM   #10
picowallspeaker's Avatar
Nonsense. Level of bass ? Go to a disco !
Let's put those speakers to use (a.k.a. my first chip amp) jure965 Chip Amps 3 9th November 2013 10:12 PM
Chip amp output for speakers macson Chip Amps 9 20th March 2013 08:35 PM
will this chip amp power these speakers merickrc Chip Amps 3 6th March 2009 05:02 PM
Best chip Amp for small Computer speakers? Ricren Chip Amps 6 16th July 2006 06:55 AM
chip amp with Orion speakers ? sl_1800 Multi-Way 10 5th December 2004 12:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
