LM3886 Parallel Output Wattage? - diyAudio
Old 28th March 2015, 03:03 PM   #1
Joseph1 is offline Joseph1  Sri Lanka
Arrow LM3886 Parallel Output Wattage?
In single ended LM3886 datasheet says
68W--4 Ohms--28V
38W--8 Ohms --28V
My question is LM3886 in parallel (2chips) what will be the output wattage?
4 Ohms--28V what is the output wattage?
8 Ohms --28V what is the output wattage?
Old 28th March 2015, 04:58 PM   #2
I can't say I've thought about. But it seems Mr. Elliott has:
Bridging Adapter For Power Amps
Simplest Ever Bridging Adapter for Amplifiers
Old 28th March 2015, 05:02 PM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
I would bridge them. If you do, the load must be decreased to 8R minimum to acheive 68W maxmum. The substrates will not take anymore. If you parallel them, it is an unknown as the amplifiers cannot be 100% matched.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 28th March 2015, 05:30 PM   #4
working with power is quite confusing for the question you have asked.
Work instead with Voltage.
eg
PSU is +-28Vdc when maximum output is passing and +-31Vdc when the output is open.
The loss through the amplifier is stated in the datasheet. Let's assume a value of 3Vloss.
The maximum unclipped peak voltage (when passing current through the rated load resistance) is therefore 25Vpk (28Vdc-3Vloss).
The maximum unclipped peak voltage when the load is open is 31Vdc-~1Vloss, ~ 30Vpk.
Now you have two amplifiers in parallel.
The maximum output is still 25Vpk.
Does the power output change?
No, because the maximum output voltage has not changed.
If you need those voltage converted to power use the standard formulae:
P=IV=IR=V/R (this applies to DC voltages and also to rms values of AC voltages).
If you use peak voltage of a sinewave, then the formulae need to be modified for the non rms/DC values and become
P=IpkVpk/2=IpkR/2=Vpk/R/2 (this only applies to undistorted sinewave).
That 25Vpk is equivalent to 25*25/8/2 = 39W, pretty close to that 38W figure in the earlier post.
A bridged pair of amplifiers is capable of delivering double the power into double the load impedance. The total power of the two amplifiers is EXACTLY the same as the output from the bridged pair. For the above case of two amps with 25Vpk output, then they are capable of delivering 39W+39W into 8r0+8r0, i.e 78W into 16r.
regards Andrew T.
Old 28th March 2015, 11:15 PM   #5
correct.
if the amplifier can not drive impedance less than 8 ohm than its true.
if it can drive a 4 ohm load, then things get a bit more complicated.
68W--4 Ohms--28V
38W--8 Ohms --28V
let us assume it stands true.
and let us assume you have an 8 ohm load.
if you bridge the amplifier,
you can not drive a load under 8 ohm. as both amps will see an 4 ohm load.
and will deliver the 68 -ish watt as they should.
in real life something around 120 watt is what you get.
just like andrewT wrote.
double the power into double the load.
if you have an 8 ohm speaker and use
LM3886 , you get 38W--8 Ohms --28V .
if you build it in bridge mode, you get about 120 watt into 8 ohm.
if you paralell 2 lm3886 chips into the same load, you get no extra power.
but you can use 2 ohm speakers.
and there you can get the same close to 120 watt as with bridge config.
V*A=VA
V*A*PowerFactor = WATT
Old 29th March 2015, 12:02 AM   #6
wwenze is offline wwenze  Singapore
http://www.ti.com/lit/an/snaa021b/snaa021b.pdf
Page 6
Old 29th March 2015, 01:05 AM   #7
Ok thanks guys.
Hmm that means in parallel mode it still delivers 68w in a 4 ohms speaker.which is not enough.
I need to build a powered sub amp that delivers 100w or 120 w into 4 ohms speakers.
Whats the best method to achieve that?
Old 29th March 2015, 01:13 AM   #8
bridge it, it will give you approx 120 watt into 4 ohm.
V*A=VA
Old 29th March 2015, 03:25 AM   #9
expert in tautology
bear's Avatar
For a sub, buy a plate amp or a digital amp module?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- [...2SJ74 Toshiba bogus asian parts - beware! ]
Old 29th March 2015, 04:02 AM   #10
Originally Posted by wwenze View Post
Hi that's why many people confuses (including me) regarding output power.
Datasheet shows this in page 6.
LM3886 in a two-device parallel solution driving a 4Ω load will typically provide 110W of output power.
Even ebay sells parallel amps using LM3886 mentioning 120W per channel into 4 ohms load.
Confusing.
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
LM3886 parallel output resistors jmar Chip Amps 41 2nd May 2013 11:08 AM
Question about wattage of resistance in parallel Rotus623 Solid State 2 22nd November 2010 04:15 PM
Parallel LM3886 output resistor(s) markiemrboo Chip Amps 4 22nd July 2007 09:03 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
