Bridged and Parralleled to drive two ohm load
Old 30th January 2004, 11:28 PM   #1
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
Default Bridged and Parralleled to drive two ohm load
I have searched the forum, but i have not found any information about people using gainclones with two ohm loads. i have tried bridging and parralleling four chips (OPA548, OPA541, and OPA549), which will run a four ohm load safely. would i need to bridge and parrallel eight chips to get a safe output into a two ohm load?
i realise the power supply, and heatsink for this sort of amp would be huge, and this question is purely theoreticle(spelling?).
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 31st January 2004, 02:20 AM   #2
GregGC is offline GregGC  Canada
Default Re: Bridged and Parralleled to drive two ohm load
You'd need to bridge them if you are driving loads more than 8Ohms load or you have limited PS voltage (car amps). That way you have double the amount of voltage across the load. In your case look at paraleling only. I don't see a reason to bridge them. You have enough voltage from the PS (don't go more than 18-0-18VAC). By paraleling ic's you can put more current through the load (that's what you need at 2Ohm loads).
I don't see any reasons not to work if you connect 2 or 3 or 4 in paralel (depending on how much power you need).
This is very informative.
http://www.euronet.nl/~mgw/diy/amps/...inclone_1.html
http://diyaudio.com/forums/showthrea...855#post181855
Old 31st January 2004, 06:37 AM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I think 2-4 LM3886 will work just fine depending of needed power.
http://www.national.com/appinfo/audi...gn_Guide13.xls
http://www.national.com/appinfo/audi...sign_Guide.pdf
http://www.national.com/an/AN/AN-1192.pdf
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 27 pcb's in interest.
Old 31st January 2004, 07:13 AM   #4
peranders's Avatar
Matttcattt you must start in one end: Not bridged => max voltage => Gives this voltage enough power in 2 ohms? If yes, estimate how many LM3886 you must use in parallel. If no, you can bridge connect, gives you the double voltage, estimate how many LM3886 you must have in parallel.
If you want rather much power maybe it's better with an discrete built amp?
Old 31st January 2004, 09:10 AM   #5
Matttcattt's Avatar
Default Re: Re: Bridged and Parralleled to drive two ohm load
This is purely theoreticle.
Old 31st January 2004, 09:43 AM   #6
tbla is offline tbla
rowland uses 6 lm3886 in parallel and they are bridged against 6 others - 12 in total with a 1200va sm supply (monoblock)......and his cooling arrangement isn't that big - i suppose it works or it wouldn't be on the marked, and the price is as high as the competition......
Old 31st January 2004, 02:20 PM   #7
Matttcattt's Avatar
what is the output of this monster?
Old 31st January 2004, 02:35 PM   #8
peranders's Avatar
Default Re: Re: Re: Bridged and Parralleled to drive two ohm load
Indeed, but if you can't do a theoretical calculation, it's much harder to know what you can achieve.
42 volt is max => 35-37 V peak out => gives you 342 W at 2 ohms.... max.
One bridged pair can take 8 ohms load => you may need 3-4 pairs = 6-8 LM3886.
If you really need 8 pcs of LM3886 you can make a really expensive discrete amp for the same price.
Old 31st January 2004, 02:57 PM   #9
http://www.jeffrowland.com/Model%2012%20Page.htm
Old 31st January 2004, 06:47 PM   #10
Matttcattt's Avatar
Default Re: Re: Re: Re: Bridged and Parralleled to drive two ohm load
i am using OPA549, not LM3875 or ML3886. I have 6 OPA549, and i was thinking of usign these to create a prototype (if i ever try this idea). 342W, wow, even 200W would be impresive.
cool
Bridged and Parralleled to drive two ohm loadHide this!Advertise here!
Bridged 4780 for 4ohms load? jaste Chip Amps 18 26th May 2010 05:46 PM
Bridged current-drive amp? annex666 Analog Line Level 7 3rd June 2008 04:21 PM
P3A Bridged Into 4 Ohm load kinser Solid State 0 12th August 2005 02:09 PM
can tda1514a bridged hold 4 ohm load? rulezzz Chip Amps 7 6th January 2004 02:14 PM
