LM1875 transconductance amp
I've got some LM1875 for free use to test several circuits and I'm building this one right now >
On the other hand I've got the complete output transistors, even the matched ones still matched, of a Rotel RA-06, and would like to get them to know a LM1875. Maybe there will/ could be love?
greetings
Jochen
Still working on my 2 1/2-way active LM1875 speakers. 1st version with crappy wood and non inverting Amps I gave up for a new version built of MDF with triple Trans-Amp. Work is still in progress but Ihave got some pics:
Hi
Revisiting an old thread since I always wanted to try a transconductance amp. since I have full range speakers and the article from NP convinced me to one day give it a try.
Thanks to the good as built schematic of Bimbla and the great help from Prasi a PCB layout has been created. I will try to fire it up very soon and will keep you posted.
I attached some pics of the empty and stuffed PCB (need to find my LM1875
Once tested I'll have some PCB to sell at cost + shipping (cheap)
BR
Eric
I am even later to the party. I am using a pair of full-range speakers with an ACA, but was also intrigued by the TransConductance paper by Nelson Pass.
Do you still have any of the boards to sell? If not I can build one myself, but shipping from China takes foorrreeeevvvvveeeeeerrrrrrr.......
8)
It is mixed design, only for stability and dc-offset if speaker wires are disconneted. Zobel network seems to be double, but one is in fact compensating gain for high frequencies in current feedback loop. I used metallized polypropylene film capacitors.
