Actual capacitance on V+ & V- (gainclone)
Old 28th January 2004, 11:34 PM   #1
Joshua Layne is offline Joshua Layne
Joshua Layne's Avatar
Question Actual capacitance on V+ & V- (gainclone)
Hi all,
I had a question about the recommended capacitance on the V+ and V- legs of the chip (say the LM3875...)
ASSUMING 1000uF as the value we are going to use (because the actual value is not part of my question), I will also be using a single transformer, single rectifier bridge to power a stereo set.
In this case, isn't he ACTUAL capacitance of the circuit at that point (pin 4 of the chip, for example) 2000uF??
Thanks for any response
see picture (section in question is RED):
Old 29th January 2004, 01:22 AM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Actual capacitance on V+ & V- (gainclone) Send a message via AIM to Peter Daniel
Theoretically it is 2000uF, but I wouldn't loose any sleep over it. Just put 1000u at each chip's supply pin and it will work fine.
Old 29th January 2004, 01:24 AM   #3
hifi is offline hifi  Sweden
Use separate diodes for each channel and they should be separated
/micke
Old 29th January 2004, 01:45 AM   #4
Thanks for the replies
Somehow my picture didn't make it through review.
Is there any particular reason to leave the "AC noise" (AKA ripple) in the V+ and V- all the way to the chip and then clean the power right at the end ?
I was thinking of including the filter caps in the power supply chassis and running ~DC (still somewhat dirty) to the amplifier chasses.
Is the idea that it filters out any accumulated noise as well? Does the ripple from these power lines introduce noise in the rest of the circuit?
I know, I know, I should just shut up and finish building one and then experiment...
I just like a firm basis in theory
Old 31st January 2004, 01:02 AM   #5
GregGC is offline GregGC  Canada
Read this please. (The first 3 pages at least)
http://www.analog.com/UploadedFiles/...8865AN-202.pdf
Actual capacitance on V+ & V- (gainclone)Hide this!Advertise here!
PPI Promos 25 - Actual output? Sub Ace Car Audio 12 19th January 2010 08:21 PM
Actual Pcb for Aleph-X - Can anyone help? lpm76 Pass Labs 5 24th September 2004 11:17 PM
What is the ACTUAL meaning of PMPO? da_madaxeman Multi-Way 15 22nd May 2004 04:09 AM
Actual DIY's master (amplifier) Gabster Solid State 51 27th September 2002 03:25 PM
Copyright ©1999-2017 diyAudio
