Old 28th January 2004, 05:04 PM   #1
Default Power supply transformer ratings
I have two 530VA 2X40V toroid lying around, can I use this for the gainclone project.
1. IMHO the output voltage is too high, is there any way to reduce the output voltage (like using a half wave rectifier)?
2. Also is the VA rating too much?
3. why no one use EI transformers for this application?
many thanks
DM
Old 28th January 2004, 06:01 PM   #2
elizard is offline elizard  Canada
Send a message via MSN to elizard
voltage is way too high
there's no such thing as too high VA rating
some people do use EI for their gc
Old 29th January 2004, 01:33 AM   #3
Thanks.
Could someone also kindly help me to understand the DC output voltage of the attached configuration (220V version)?
As I understand, it is a full wave rectifier with a capacitive load (also take into account the 1000uF caps, shall I?), some the DC voltage should be:
Vdc = 0.71 x Vac
and the Vac is 96V (48V x 2) in this case ... how can it be? way too high?
Where did I made a mistake?
Old 29th January 2004, 05:06 AM   #4
Anyone?
BTW, if this configuation is used, what VA rating of the transformer shall I use? is 100VA good enough, or 160VA better?
does this also mean I need 4 x 100VA (or 160VA) per channel?
Many thanks.
Old 29th January 2004, 05:29 AM   #5
out of curiosity, what are the caps and diodes between primaries for? some kind of low-level DC removal? and 1uF is pretty small for a filter cap.
and why not just draw it as 4 diodes in a row down in parallel with 4 in a row up?
also, the unloaded Vdc will be about 1/0.707 or 1.414 Vac, this is because the caps will chrage to the peak voltage, and without any load they will never discharge. adding a load will create a ripple voltage which is pretty high with 1000uF. an approximation is
I = C dv/dt = C Vrip 2 pi f
so
Vrip = I/ (2 pi C f)
where f is either 50 or 60 for half-wave, or 100 or 120 for full-wave.
i assume your looking for voltage rails of about 24-33V per rail, +-24 to +-33V ?
if only it could be used for good, not evil...
Power supply resistors power ratings Nihilist Tubes / Valves 13 31st July 2009 01:47 AM
Choke input power supply, capacitor ratings 00940 Tubes / Valves 14 7th July 2009 05:52 PM
Output transformer current and power ratings boywonder Tubes / Valves 3 29th April 2009 09:00 PM
Question about Allied & Hammond Power Transformer Ratings Bitrex Tubes / Valves 2 6th March 2009 07:31 AM
Transformer ratings??? AR1 Power Supplies 2 2nd May 2005 07:02 PM
Page generated in 0.10828 seconds (70.45% PHP - 29.55% MySQL) with 11 queries
