Interesting Find - Car Audio CHIPAMP?? - diyAudio
Old 20th February 2015, 03:22 PM   #1
Addicted to Sound
Default Interesting Find - Car Audio CHIPAMP??
I found this GEM on ebay and purchased not know what it really was. At first I had assumed it was simply your standard mosfet amplifier until I received it. I always look at the idea of recapping or modifying amplifiers (doesnt everyone?) and in doing so realized wow- this thing is a chip amp!
2x65w Sound familiar gainclone fans?
has 2x 3886 chipsets
Anyone have further information about this? Any updgrades recommended on this amplifier or power supply section? REcap or no?
Era is said to be 1996-1998?
Lots of spaces for added components said to be because there is a 4 channel version around?
Would like any/all information, comments, suggestions- Thanks!
Old 20th February 2015, 04:10 PM   #2
johnr66 is offline johnr66  United States
Can't be that old as the 3886 was introduced in the mid to late 1990's.
You'd have to check the components' condition and quality to determine if worth upgrading.
No model number, no link or pics? Not much more advice can be given.
Old 20th February 2015, 04:31 PM   #3
Addicted to Sound
Default Pics
Not sure why these didnt come through..
Old 20th February 2015, 04:32 PM   #4
Addicted to Sound
Car audio LM3886 + SMPS on single sided board last post here has pics- moderator is reviewing pics for here!
Im guessing 1995 to 1998 on production
Old 21st February 2015, 02:14 PM   #5
If it is working alright, I'd leave it as is. I'd take some power measurements. Seems to be based on around +/- 25v rails (under load) by looking at the transformer. What are the ICs to the far left. They seem discolored.
Old 1st March 2015, 03:05 PM   #6
Addicted to Sound
I'll try and find a better look
Old 1st March 2015, 03:08 PM   #7
Addicted to Sound
John,
Is it not worth recapping if it's build date was 1998?
Old 2nd March 2015, 06:03 AM   #8
jerluwoo's Avatar
Never seen a U.S.Amps amplifier with chip amps, but, that unregulated supply with tip35c's was used in nearly all of their amps through out the 90's. Unless there's an obvious problem I would let it be and use it.
Old 2nd March 2015, 02:31 PM   #9
Addicted to Sound
Right on, I always consider if there would be improved sound by using better caps, etc.
Thanks for advice!
Old 2nd March 2015, 03:15 PM   #10
phase is offline phase  United States
That is a neat amp, I might try some small film/foil bypass caps on the small electto caps near the power pins. Does it have input caps, or straight through DC coupled?
Interesting find Howard Multi-Way 15 4th February 2015 12:24 AM
Which chipamp for car audio Robzy Chip Amps 13 26th December 2009 04:53 PM
interesting idea from car-audio theChris Solid State 3 25th July 2006 05:42 PM
MR. Pass might find this interesting... Frazzled Pass Labs 10 18th May 2004 10:05 PM
Where can i find everything i would need to know, about car audio? zJQz05 Car Audio 3 26th December 2003 08:28 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
