Old 27th January 2004, 07:20 PM   #1
2Bak is offline 2Bak  Denmark
Default 100K Noble logarithmic pot
I'm building another GC using the below schematic.
I have a Noble 100K logarithmic pot, type 204.
I've seen that people recommend linear pots for GC's.
Can I compensate in some way using this logarithmic Noble? If possible, what should I do...?
By the way, why are logarithmic pots not recommended?
(Haven't soldered it in yet, so I haven't heard the amp in action with this Noble).
Thanks.
/Jan
Old 27th January 2004, 07:23 PM   #2
this one
Old 27th January 2004, 07:38 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I'm very curious why they are not recommended? I used exactly the same pot in the same circuit and it works fine.
Wht is not recommended, is the 100k value. I'd rather go for 50K, but if not available 100k will work too. Actually, I tried linear pot in this location, and I prefer the action of the logarythmic one.
Old 27th January 2004, 07:49 PM   #4
Thanks for your information, Peter. I didn't mean that Nobles were supposed to be not recommended.
However, in this schematic someone (?) recommends linear tapers: http://ampchipdiy.com/invertedLM3875_r2_1.gif
I will use this 100K Noble 'cause I have it already.
/Jan
Old 27th January 2004, 07:51 PM   #5
Well, I tried both (linear and logarythmic) and logarythmic gives better control range. BTW, those Nobles are pretty good sounding pots.
Also, Noble 204 curve has pretty nice split and might work better than some other logarythmic pots (with 10/90 split)
Old 27th January 2004, 07:56 PM   #6
Yep, I've seen you mention this before...I tried an old Alps Black Beauty 100K first, but took it out 'cause channels were not in balance. Looking forward to trying this Noble.
Old 27th January 2004, 10:26 PM   #7
Peter-
I am building stepped attenuators for an LM3987 IGC feeding a pair of 90db speakers. But I only have 12 steps to my switches. Can you rec 12 resistor values for a most useful set of 12 steps?
Thanks,
GnD
I had the right to remain silent. I just didn't have the ability. (Comedian Ron White)
Old 27th January 2004, 10:46 PM   #8
There is a 12 step attenuator in this link http://www.geocities.com/rjm003.geo/...io/diy_gc.html
If I would be doing one for me, I would use 2db steps from full volume down (-22dB would be 11 pos and OFF would be the last one). I don't listen at rally low volumes so this would work well for me.
In here, there are some values listed as well: http://www.penguinlovers.net/audio/Attenuator.html
Another calculator here: http://homepages.tcp.co.uk/~nroberts/shunt.html
Logarithmic Pot. instead of linear? suicida Parts 4 23rd February 2009 11:04 PM
FS - Toroidal trafo (25V/300VA) and Noble volume pot (100K) - UK mubeen1983 Swap Meet 6 25th October 2008 09:16 AM
Noble 100K pot. mattjk Swap Meet 0 21st January 2008 02:50 AM
Logarithmic potentiometers eeka chu Parts 3 31st December 2004 01:17 PM
Logarithmic attenuation FunkyStu Solid State 4 31st December 2003 02:54 PM
Page generated in 0.13498 seconds (76.00% PHP - 24.00% MySQL) with 11 queries
