Which chip will be better than LM3886? - diyAudio
Old 28th January 2015, 02:33 PM   #1
Default Which chip will be better than LM3886?
I have tried the LM3886, I like it. I would like to build another amp, and would like some recommendation on which chip may be better - I am not keen on high wattage 20W should be fine but would like low distortion. It will be used for near field listening only.
Old 28th January 2015, 02:36 PM   #2
bimo is offline bimo  Indonesia
bimo's Avatar
I like LM1875 than LM3886. You should try it...
Old 28th January 2015, 02:36 PM   #3
Can you define better? There are certainly different implementations of the LM3886 which vary wildly in performance and are discussed on these pages. Perhaps try a more optimised 3886 build and see if you can tell the difference?
Old 28th January 2015, 02:51 PM   #4
bimo's Avatar
I use schematic from the datasheets. High frequency more "clear" on LM1875.
Old 28th January 2015, 03:00 PM   #5
more clear? OK...
Old 28th January 2015, 03:18 PM   #6
Michael Bean's Avatar
The schematic only shows component connections, and that is only one part of what makes a successful build. The physical layout is also important and will have as much or more impact on performance as which components are selected for use. A poor circuit layout using premium parts won't perform as well, and won't sound as good as a proper layout using ordinary parts. Things like getting the power supply decoupling, circuit paths and grounding scheme right are critical for getting the best from these devices. As "they" say, the devil is in the details.
Mike
Old 28th January 2015, 03:24 PM   #7
I purchased the assembled kit from ebay.
The PSU is interesting, I know a lot of audiophiles don't like this setup - here is what I did.
I connected 2 DC-DC boost converters to two 12V 5 A switching supply to get +/-30V. This I cleaned up using LM350 and a low pass filter. The sound is pretty good. Silent, no hum, no hiss.
Old 28th January 2015, 03:26 PM   #8
bimo's Avatar
Mike
I agree. My design better than both Lm3886 and Lm1875.
Old 28th January 2015, 03:28 PM   #9
What is 'better' about your design? Other than it's yours and therefore to you will always be better?
Old 28th January 2015, 03:29 PM   #10
PSRR on a raw LM3886 is not wonderful. you may want to build a better PSU as your next project. Taming the LM3886 Chip Amplifier is a really good read if you have not seen it.
LM3886 Chip Amp Getting VERY HOt bdiermeier Chip Amps 21 7th January 2014 03:27 PM
LM3886 chip amp help danielnaveen Chip Amps 31 31st January 2011 02:33 PM
First chip amp - lm3886 agithegreat Chip Amps 31 5th April 2010 03:35 PM
My LM3886 chip amp Denis.BR Chip Amps 13 19th October 2007 02:15 PM
My LM3886 Chip Amp bhk Chip Amps 9 22nd March 2006 12:33 AM
Copyright 1999-2017 diyAudio
