If you think a TDA1524 is a solution for anything involving "high quality", then you should probably read its datasheet again. This noisy old bugger was used in compact stereos and the like, where it belongs. I wouldn't touch that one with the proverbial 10ft pole, ditto for the LM1036. Just not HiFi.
Do you really need an all-singing, all-dancing IC? Something modern like a NJW1194 may be a better bet then. That, or you just implement it with a bunch of opamps, like P97 (you can also use something better than ye olde TL072, like TLE2072 or OPA2134).
