Old 25th January 2004, 08:21 PM   #1
Default why o why doesn't this work ? Balanced 549
I tried this idea to drive the balanced output of my Roland E660 in a gainclone. Used chips are OPA549. No bad smell, no DC on the output but also no sound They are powered with 2 12v batteries wich gives a -12 and +12 rail. Also there's a 0,1 µF cap over the 2 rails.
Even when i connect just one on a unbalanced output still nothing.
The only thing i hear is a slight *pop* in the speakers when I power the 549's.
Old 25th January 2004, 11:44 PM   #2
Matttcattt's Avatar
i asume you mean the OPA549? what have you connected the current limiting and Vref pins to? there will be no output unless the are both set. the easiest way to do this is to connect them both to ground. this will set the current limit to maximum (10A).
have fun.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 26th January 2004, 02:15 PM   #3
both are connected to the ground, wich in this case is the plus and minus from each batterie. -12 gnd +12
Old 26th January 2004, 02:30 PM   #4
runebivrin's Avatar
Send a message via MSN to runebivrin
Is the ground of output from the Roland connected to anything? Quite often balanced outputs are created without a transformer, and since your input is transformerless, you really need to connect the grounds together.
Rune
Do wizards use spell checkers?
Old 26th January 2004, 02:44 PM   #5
yup, those are connected to the ground as well.
mmm, i was fiddeling a bit. Now i got his very hard sounding clipping music true the speakers. Well not music, more static/hum on the beat of the song.
Old 26th January 2004, 03:29 PM   #6
Banned
Excuse me, maby I need a cold beer, but is that a balanced GC?
Two IGCs?
Old 26th January 2004, 04:23 PM   #7
Matttcattt's Avatar
yes.
sorry to hear about the hum. i cant really help more, as i dont know anything about balanced inputs/outputs.
Old 26th January 2004, 04:52 PM   #8
I just red the datasheet over again, in wich stated that ref. pin must be als low as the negative voltage if V- is used. So in my case -12. Sadly enough I don't have anymore samples avaible so this project has to wait.
@carlosfm, actually this is a bridgeclone. But you can call it a balanced amplifier since you use the - in / + in to drive it.
Old 26th January 2004, 05:08 PM   #9
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
What have you done with the E/S pin? (It shouldn't be connected to anything when REF and ILIM is at GND)
As long as you have a psu voltage above +/- 4V, you can connect REF and ILIM to GND.
Mads K
Old 26th January 2004, 05:18 PM   #10
E/S pin is cut off
My scope doesn't work - need help! Giaime Equipment & Tools 17 23rd September 2011 06:47 AM
Help-Car deck Doesn't work jatminder Car Audio 2 10th July 2006 08:13 AM
Right Channel on my amp doesn't work?? nicku1302 Solid State 2 29th November 2005 03:58 PM
adcom gfa 545 II doesn't work Mattyo5 Solid State 1 14th February 2004 12:39 AM
Page generated in 0.11670 seconds (67.88% PHP - 32.12% MySQL) with 11 queries
