I looked at the XY PCB layout seems you can put a small resistor in series on the input gnd leg to the panel conn. ( least this should check my theory ) EDIT , BTW this would of worked but its difficult now.I connected all the input ground wires with short wires on the PCBs, and all the hum is almost gone! I still got a little bit of hum in one of the speakers, but it's much better!
not sure about the sub amp , is that the worst one now?
this often helpyou can put a small resistor in series on the input gnd leg
Can I just screw a 2 ohm resistor at the input terminal, and solder the input wire to it? that's a much simpler process than cutting all the traces underneath each PCB. Bu if I do this, what should I do with all the ground wires I've connected to each input terminals? Aren't these necessary anymore?
Hansibull, is it your intention to use the 5/1 diy amp in addition to the 7 amps already present in the receiver or are you building to upgrade the receiver?
My idea was to use the pre out connectors that the Marantz have, and make my own, quality amplifier, instead of the the internal amplifier in the AV receiver. It will just be a 5.1 system, and no extension
When it cones to noise, the center speaker, left front speaker, the subwoofer and the surround right speaker is completely silent. I still got some hum in the front right speaker, and the surround right speaker.
I don't think any of the LM3886 kits sold on ebay will outperform the Marantz amps, not in quality or in power.
hehe that's not helping him, it's sorta like kicking a guy when he's down.
yes that would be in series with the input gnd, as a work around try 10 -100 ohms in series like you described, (yer still in trouble shooting mode).
Based on symptoms you reported, we are trying to reduce any stray PS or line AC currents from running thru the coax cables.
No. That puts the added resistance into the input pair and INCREASES the interference voltage fed to the amplifier.Can I just screw a 2 ohm resistor at the input terminal, and solder the input wire to it? that's a much simpler process than cutting all the traces underneath each PCB..
Download D.Joffe's article. He shows where the ADDED resistance should be located to REDUCE the interference voltage fed to the amplifier.
The ADDED 2r resistor is NOT in the signal pair feeding the sig hot and sig return.I looked at the XY PCB layout seems you can put a small resistor in series on the input gnd leg to the panel conn. ( least this should check my theory ) EDIT , BTW this would of worked but its difficult now.
Putting an added resistor into the sig return is NOT the place to locate the interference reducing resistor.
I don't agree with Mark.hehe that's not helping him, it's sorta like kicking a guy when he's down.
I have only the experience of opening up one "all in one" surround capable amplifier.
If the Marantz is anywhere near as bad as the Yamaha, then a well built 3886 will easily beat it.
don't stop him, its just an experiment in trouble shooting. He reported the hum comes when the coax cables are connected to other gear. BTW maybe you missed the part where I gave him the link for a thread that describes a better fix for XY PCBs.
My next post addressed the possible two locations for the added resistor........... maybe you missed the part where I gave him the link for a thread that describes a better fix for XY PCBs.
The link you gave may be correct.
The signal return lead is definitely not the correct location for an added resistor to reduce interference.
well maybe you can explain the cause after he reports back with the data.
Im just helping the symptoms like any Rx
D.Joffe article on hum loop and attenuating interference
two recent links to Joffe's paper.
http://www.diyaudio.com/forums/soli...ichael-bittner-our-mikeb-198.html#post4024136
http://www.diyaudio.com/forums/analog-line-level/265232-comment-grounding-scheme-11.html#post4170245
- Chip Amps
- LM3886 surround amp; problems with 50Hz noise
