eBay LM3886 parallel kit - diyAudio
Old 15th January 2015, 08:57 AM   #1
Default eBay LM3886 parallel kit
Has anyone tried this kit?
120W 120W LM3886 Dual Parallel Multicenter Amplifier Board Ref Jeff Rowland | eBay
Unfortunately I could not get a schematic, which is quite common on eBay.
This is for a friend of mine, not for me. I did buy a MyRef clone kit from eBay some time ago, which did sound very good.
Old 16th January 2015, 01:27 PM   #2
A kit without assembly instructions?
Or is it just the schematic that is missing?
regards Andrew T.
Old 20th January 2015, 12:38 PM   #3
The schematic is missing and/or they do not have it or do not want to show it.
AFAIK the kit is assembled, so there shouldn't be any assembly instructions.
Old 20th January 2015, 01:57 PM   #4
jackinnj's Avatar
That's a pretty impressive store.
Old 23rd January 2015, 12:47 AM   #5
tomchr is offline tomchr  United States
tomchr's Avatar
You'll probably still have to adjust those 10-turn pots. I assume they are for nulling out the voltage offset differences between the different LM3886es.
The board should at least come with assembly/use instructions and an adjustment procedure.
~Tom
Modulus-86: Composite amp achieving 0.00018 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right
TDA7293 Parallel kit from ebay (modular/slave style, no lossy emitter resistors) danielwritesbac Chip Amps 220 10th December 2014 03:30 PM
LM3886*3 Amp ebay kit FOXYE Chip Amps 7 13th August 2014 04:47 PM
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 06:50 PM
LM3886 Parallel Use Rachel Chip Amps 71 2nd July 2006 05:24 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
