Modulus-86  build thread
Old 16th July 2018, 07:23 PM   #4301
chrisb is offline chrisb
Gorgeous - where did you get the chassis?
like my mind, this space intentionally blank
Old 17th July 2018, 08:59 AM   #4302
supernet is offline supernet  Europe
supernet's Avatar
Originally Posted by tomchr View Post
Dang! Nicely done, Sir! Thank you for sharing.
Tom
Thank you Sir It was pleasure to work on this project, as everything went out perfectly smooth. I would do it again any time. Any volunteers?
Thx Somewhere on Alliexpress some time ago.
Old 17th July 2018, 12:45 PM   #4303
jameshillj is offline jameshillj  Australia
I think it's a BreezeAudio case, either a 3209 (320w x 90 high x ...) or the smaller 2107 (210w x 70hi x ...) in millimeters - there's quite a few of them with similar sizes - another recent name is 'Queenway'
Old 20th July 2018, 02:35 AM   #4304
tomchr is offline tomchr  Canada
tomchr's Avatar
Inductors! So many inductors...
These'll work with the Modulus-86 (Rev. 2.3 and beyond), Modulus-286, Modulus-686, and LM3886DR.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 23rd July 2018, 06:29 PM   #4305
brian92fs is offline brian92fs  United States
I've been mulling over that, actually. All one has to do is to detect the input differential voltage of the LME49710. If that deviates significantly from zero, the amp is clipping. The trick is to do so reliably and cleanly. I'd probably also want to play a bit with the timing of the light itself to ensure that even a brief clip will be indicated.
Tom
Hi Tom,
I'd be interested in a clipping detector if you were to offer one.
Old 24th July 2018, 05:04 AM   #4306
tomchr's Avatar
I'll keep that in mind. Thanks.
Tom
Old 29th July 2018, 08:30 AM   #4307
radiotron is offline radiotron  New Zealand
Build of a rev 2.1 in progress. Very nice board to work with, as is the documentation.
Old 29th July 2018, 05:12 PM   #4308
nycavsr2000 is offline nycavsr2000  United States
nycavsr2000's Avatar
Keep it up! The sonic rewards are well worth it!
Best,
Anand.
Old 30th July 2018, 10:16 PM   #4309
tomchr's Avatar
Very cool. Thanks for sharing. It's rare that we get to see the "build in progress" type of pictures.
Tom
Old 1st August 2018, 01:56 PM   #4310
HIFI0101 is offline HIFI0101  Bangladesh
Whos site is this? is this thing comes with all the componets to populate the board for 69$ or just the board?
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2405 13th September 2017 06:10 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
