Modulus-86  build thread
Old 16th April 2018, 06:01 PM   #4001
zgtc is offline zgtc
Originally Posted by tomchr View Post
Thanks to everybody who have contributed so far, and especially thanks to Bill who started this thread. He has yet to finish his amp but has grown his family exponentially instead. Bill! This the year! No pressure...
hey that gives me 2.5 yrs of extra margin... got mine last summer
Old 16th April 2018, 07:10 PM   #4002
tomchr is offline tomchr  Canada
tomchr's Avatar
Nice...!
My website is now operational again. Back in business.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 16th April 2018, 10:03 PM   #4003
brian92fs is offline brian92fs  United States
So I thought I'd ask: Are there any other features that you'd like to see in this supply board?
I like the idea of support for a CRC snubber network. Even if the snubber doesn't benefit the Modulus amplifiers measurably, it would make the power supply have broader appeal for usage in other amplifiers that might not be so forgiving with their power supply.
I agree that a 12 V trigger input is a nice addition.
What about an option to use discrete diodes vs bridge rectifiers? Would that be getting to complicated?
Also, for the +5 V always on auxiliary output, would this be powered from a separate transformer?
Old 16th April 2018, 10:12 PM   #4004
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
Thanks all!
Tom
Every morning when I leave for work I see a board against the headsink and think I should start the swarf and sawdust making. Making progress with sleep training youngest one so I am hopeful of news soon...Honest
Old 16th April 2018, 11:06 PM   #4005
BigE is offline BigE  Canada
BigE's Avatar
You need to match the snubber to the transformer. It does work to reduce ringing. The quasimodo no math jig works great to select resistor values.
Old 16th April 2018, 11:09 PM   #4006
That's my understanding. But it would be nice to see component provisions for this on the PCB so the buyer could implement if they desired. Knowing they'd need to determine the values specific to their transformer as you described.
Old 17th April 2018, 02:43 AM   #4007
tomchr's Avatar
That's basically my thought.
To support a stereo Modulus-686, the diodes will very likely need to be discrete anyway. Discrete with heat sinks. So either a TO-220 or TO-247 package kind of deal.
I'm thinking a Mean Well switcher. They cost about a quarter of what a transformer-based supply would cost, are dead quiet, and take international mains in.
True. But so does the single cap across the transformer secondary - and that, in contrast to the RC snubber, does not need to be sized to the transformer. I can certainly include instructions for how to determine the RC snubber should anyone desire to pursue that angle, but optimizing the snubber to the transformer (and its wiring harness!) will be up to the end user.
Tom
Old 17th April 2018, 03:21 AM   #4008
wcwc is offline wcwc  United States
Any idea yet how big the board will be compared to the Power-86? Would anything change with regards to the required transformers?
Old 17th April 2018, 05:22 AM   #4009
HarmonicTHD is offline HarmonicTHD  Switzerland
My two cents to the Power 686.
I also like the CRC snubber option, the 12v trigger and of course the soft start.
To further increase flexibility and appeal to non Mod users I could imagine to leave some room for the capacitor diameter so people can use even larger caps than the two 22000uF per rail.
Old 17th April 2018, 03:09 PM   #4010
tomchr's Avatar
No changes to the transformer.
The board will probably be twice as long as the discrete diodes + heat sinks take up quite a bit of room and allowing for twice the capacitance will take up some space. Add 1.0-1.5" to the width to accommodate the Mean Well switcher and associated bits. Fitting the board within 5x6 to 5x7 inches would be pretty nice. The current Power-86 is 3.3x3.6 inches.
No promises on the board size. I'm familiar with the various constraints of shoehorning an amp into an enclosure and will keep those constraints in mind when deciding the board size. The board will be large enough to accommodate the features but no larger than that. Smaller is better when it comes to board size.
I hear ya. The Power-86 supports two 40 mm diameter caps. The two caps I specify are actually 35 mm in diameter. So there's room to grow. 40 mm gets up to 27000 uF (27 mF) per cap for 50-63 V snap-in types. The next sizes up are 50 mm and 63 mm diameter. Mouser shows exactly one (1) non-stocked 33 mF 50 mm cap in the 50-63 V range. The two (2) 63 mm caps are both 22 mF (and non-stock as well). The difference between 27 mF and 33 mF is negligible in this context, honestly.
This is how I landed on the 40 mm footprint in the first place. There are quite a few options to choose from in the 35-40 mm range.
So I'll stick with the 40 mm footprint. I did take into account when designing that footprint that a "40 mm" specified cap may be a tad larger due to production tolerances and the footprint can accommodate that too. If the resulting 4x27 mF = 108 mF isn't enough capacitance for you, you'll probably want to go with the chassis-mounted screw terminal caps rather than board mounted caps.
I use 10 mm pin pitch on the caps, so you have tons of options to choose from.
Tom
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2405 13th September 2017 06:10 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
