Modulus-86  build thread
Old 28th December 2017, 10:53 PM   #3731
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Sad, strange man that I am I have been on the hunt for music with a very high crest factor. This is not helped by the fact that calculating crest factor on real music in a meaningful manner is tricky and you end up with averages of averages, but the foobar DR plugin gets to the right order of magnitude despite not actually calculating DR! But it does give you RMS level and peak (sadly ignoring crescendos in classical music) so is a pointer for looking further. There are not many recordings with very high crest factor and even fewer you would want to listen to, but I've found a few and am sampling them. I have a Rickie Lee Jones track where the RMS level is -24dB with peaks of 0dB. It's a good test for if you have enough amplifier headroom .
My heatsink torture test is Rodrigo y Gabriela which is smushed to death...
All of which is making me think that THX reference levels (-20dBFS is 85dBa or 75dBa* per channel at listening position) are a good starting point then adjust gain according to the RMS level of the track.
*The 75dBa spec is probably more applicable for those of us without basement home cinemas and who value our hearing .
Old 28th December 2017, 10:58 PM   #3732
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Originally Posted by tomchr View Post
How long is your speaker cable? The output impedance of the amp is about 20 mΩ. With an 8 Ω load, that's a damping factor of 8/0.02 = 400. The DF will be dominated by the connector resistance and resistance of your speaker cable.
Tom
Yes, I know.
Just wanted to know what value we start with.
Pretty good.
Old 28th December 2017, 11:16 PM   #3733
Bill_P is offline Bill_P  United States
foobar2000 1.1.16 / Dynamic Range Meter 1.1.1
log date: 2015-07-20 18:13:13
Analyzed: Rickie Lee Jones / Flying Cowboys
DR Peak RMS Duration Track
DR19 -3.16 dB -26.43 dB 4:50 01-The Horses
DR13 -8.97 dB -25.86 dB 4:49 02-Just My Baby
DR24 -0.49 dB -26.59 dB 6:16 03-Ghetto of My Mind
DR16 -6.39 dB -25.94 dB 4:54 04-Rodeo Girl
DR17 -4.38 dB -25.14 dB 4:58 05-Satellites
DR18 -7.16 dB -32.44 dB 4:18 06-Ghost Train
DR16 -6.03 dB -24.17 dB 5:05 07-Flying Cowboys
DR14 -7.15 dB -26.27 dB 4:20 08-Don't Let the Sun Catch You Crying
DR19 -4.11 dB -25.36 dB 4:55 09-Love Is Gonna Bring Us Back Alive
DR16 -6.24 dB -29.30 dB 5:34 10-Away from the Sky
DR13 -4.31 dB -24.21 dB 5:57 11-Atlas' Marker
Number of tracks: 11
Official DR value: DR17
Samplerate: 44100 Hz
Channels: 2
Bits per sample: 16
Bitrate: 715 kbps
Codec: FLAC
Old 28th December 2017, 11:24 PM   #3734
billshurv's Avatar
In more detail (left and right seperate)
foobar2000 1.3.16 / Dynamic Range Meter 1.1.1
log date: 2017-12-26 17:53:10
Statistics for: 3/11-(03) Ghetto Of My Mind
Number of samples: 16573956
Duration: 6:16
Left Right
Peak Value: -0.62 dB --- -0.40 dB
Avg RMS: -26.47 dB --- -26.75 dB
DR channel: 23.44 dB --- 23.69 dB
Official DR Value: DR24
Channels: 2
Bits per sample: 16
Bitrate: 650 kbps
Codec: FLAC
It's an outlier and I don't know if this is actually more realistic (as in less compressed) or just too close miked on the drum kit. But beats Dafos as a headroom test
Old 29th December 2017, 01:25 AM   #3735
BrianL is offline BrianL  United States
Bob Cordell did a presentation at RMAF a few years ago -- presentation slides are on his web site, I believe. He, too, found the 'Ghetto of My Mind' track to have the highest peak/average ratio.
bel
Old 29th December 2017, 01:32 AM   #3736
billshurv's Avatar
Yeah, Bob put me onto my latest obsession . Although I don't agree with his power requirements for the average UK listening environment. An average of 1-2W is rather loud in our little hovels
Old 2nd January 2018, 08:02 AM   #3737
Johnny2Bad is offline Johnny2Bad  Canada
in my experience, transcoding LPs to 16/44.1, I found normalizing to -13dB RMS (actually should be "average") resulted in zero clipped samples on most popular Rock / Folk / Blues albums, mostly from the 1970's. I aimed for a maximum level of -1dB Full Scale, so the actual crest factor was 12dB. Rarely would I need to normalize at -14dB RMS, and many could have been normalized to -12dB but I prefer similar average levels when possible.
Using that method, there would of course be portions of songs that had a higher crest factor, but they were down from the peak average levels in the program material anyway, so I didn't measure them.
Actual recording was done at 24/96, using some of the extra headroom to generate clean recordings (zero clipped samples, maximum level -1dB FS), de-click performed, normalized, then downsampled to 16/44.1. Some with dither, some without.
This was done before I really knew what I was doing with digital transcribing, 15~20 years ago, but based on my experience with analog recording and some educated guessing. It seemed to work out OK
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..."
Old 2nd January 2018, 08:17 AM   #3738
DF should be output impedance vs:
the sum of:
impedance of speaker wiring (both ways, eg 20 ft for a 10 ft speaker cable)
impedance of any crossover network
impedance of the voice coils of the driver(s)
impedance of any connective elements (bananas, binding posts, internal speaker wiring, etc)
We are most interested in the DF at low frequencies of the largest driver (ie with the greatest back-EMF between the minimum excursion frequency and any crossover frequency), however the "quick and dirty" method is to measure the DC resistance of the speaker wire at the amplifier output point (unconnected at amp end, connected at speaker end).
In the modern Solid State world (and in most cases, in the "Classic" Solid and Vacuum State age) DF was adequate, so it's not something I worry much about. Some suggest any complex DF above 1:20 is adequate.
Old 2nd January 2018, 08:58 AM   #3739
billshurv's Avatar
yeah a lot of 'popular' music does hang around -12dB. Or at least used to. I have a track with -6dB RMS and Tom has worse on his website. It does trip the over sensitive protection on the old amplifier, but can't be bothered to fix that as have something better still waiting installation
Old 2nd January 2018, 09:29 AM   #3740
nycavsr2000 is online now nycavsr2000  United States
nycavsr2000's Avatar
the sum of:
Good discussion. I’ve been reading Toole’s 3rd Edition of “Sound Reproductions” <highly recommended> and he discusses this in detail on Chapter 16. He doesn’t mention a DF ratio though so I presumed 1:10 was adequate. Do you have a source for your 1:20 recommendation?
Best,
Anand.
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2405 13th September 2017 06:10 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
