Modulus-86  build thread
Old 16th January 2015, 07:22 AM   #21
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by Richidoo View Post
Almost finished the amps today.
Purrdy!
The Modulus-86s took about 6 hours to build both boards.
That sounds about right. I'm at 2-2.5 hours per board. But then, my fingers have also been preset to bend resistor leads to a 400 mil pin pitch since, oh, about sixth grade...
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 21st January 2015, 03:38 PM   #22
supernet is offline supernet  Europe
supernet's Avatar
Any listening session already made with this amp?
Old 21st January 2015, 04:40 PM   #23
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
I wont be fired up for some time yet as a lot of interim steps for me.
Old 23rd January 2015, 12:47 AM   #24
Richidoo is offline Richidoo  United States
Workin on it! Hopefully tomorrow. The good weather in NC had me divert to painting. Tomorrow is rain, so I have a chance!
Old 23rd January 2015, 07:29 AM   #25
tomchr's Avatar
Default Public service announcement
Just injecting that the Modulus-86 board can be used with the LM3876 as well.
I'm listening to a Modulus-86 in >>>STEREO<<< where one channel is LM3886-based and the other LM3876-based. The supply voltage is 15 V. This is intended as a low-power build to drive a pair of computer speakers.
I stand by my previous comment that if the amp sounds good in mono, it will sound amazing in stereo. It really does sound amazing. I'm spinning Eric Clapton, "Unplugged"; Dire Straits, "On Every Street" and "Brothers in Arms". I'm seriously impressed. The speakers are Alpair 6P in an enclosure designed by Planet-10. The enclosure is originally designed for the metal cone version of the driver, but take the center port fill out and it'll work with the paper cone version.
I actually can't tell any difference in sound quality or measurements between the LM3886 and the LM3876 channels. I'm sure I can measure a few minute differences, I just haven't gotten there yet. I was a bit eager to get the contraption hooked up to my speakers...
~Tom
Old 23rd January 2015, 05:19 PM   #26
No mic cable in the house, so I can't make ICs.
Old 23rd January 2015, 05:32 PM   #27
billshurv's Avatar
Annoying. Hope you can sacrifice something to the cause. Not even a ratshack near you?
I have made interconnects out of solder in the past when desperate. And Pano has proved that 8 out of 10 listeners cannot tell a banana from wire!
Old 24th January 2015, 09:15 AM   #28
dominique-tanguy is offline dominique-tanguy  France
Default The project is strated
I have received my board yesterday. I decidied to test my capability with the easiest part, the power supply. I am still waiting for the enclosure.
So far so good... Instructions provided by Tom are very clear.
Dominique
Old 24th January 2015, 09:56 AM   #29
Philfr is offline Philfr  France
Hi Tom,
Good news !
It is available from mouser, and it looks better regarding datasheet.
For low power needed (10/15 watt) with low voltage (12/18 volts), maybe it's a good way ?
Phil.
Old 24th January 2015, 07:54 PM   #30
tomchr's Avatar
I'm running mine at 15~16 V using an Antek AN-0512 (2x12 V, 50 VA) and a Power-86 board with 2x33000 uF, 25 V caps. Works great!
To run at low voltage, you need to swap a couple of resistors on the MOD86 board to ensure proper regulation of the on-board voltage regulators. That's now described in the design doc.
If you need the latest doc, just email me. List the email address you used to buy the boards so I can find you in my records.
~Tom
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2405 13th September 2017 06:10 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
