LM3886 with SMD components - diyAudio
Old 9th January 2015, 04:20 PM   #1
mravlca is offline mravlca  Slovenia
mravlca's Avatar
Default LM3886 with SMD components
Just wanted to share with you my LM3886 stereo PCB with mainly 1206 smd size components. Some components have Farnell ordering codes in schematic for easier sourcing.
Best Regards,
Aleš
Old 9th January 2015, 10:35 PM   #2
Nice work. Thats interesting layout.
But i see a few problems:
Aren't feedback resistances too low? Thats basically 1K from output to gnd. 10s of miliamps will be flowing through them.
100nf decoupling caps are too far from LMs (C5 & C8).
There is no Mute cap. Danger of pops when turned on.
I would route C7&C6 with separate traces to star point. But this one probably makes little difference.
Why electrolytic cap on input? R2 and R8 can be easilly increased to 47K, and then small 0.68-1uF film caps on input will be enough.
Old 10th January 2015, 03:18 AM   #3
you need caps for both the rails for both the chips.
fb resistor r5 is too far.
rf filter should be close to input socket.
Old 10th January 2015, 12:15 PM   #4
mravlca's Avatar
Thank you!
If you try it you'll notice that there is nothing wrong with it and the sound of chipamp will vastly improve.
You're right about C5 and C8 but this was the best option to use only two for both of the LMs. You're also right about routing GND from C5, C6, C7 and C8 to star point, I didn't see it before.
I tested the PCB and I didn't have any turn on/off pops.
It is tantalum 10uF/16V capaitor in paralel with 10nF MKP1837 capacitor. I found this combination more neutral than any other foil capacitor and very good sounding.
Why?
You're absolutely right, I should have placed it next to R3 and R9. Trace would be then as short as possible. Still It can be solved with through hole resistor soldered directly to the pins of LMs.
How would this improve the sound quality?
Best Regards,
Aleš
Old 10th January 2015, 12:27 PM   #5
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Not good... Not good at all... Missing HF filters on supply rails. There's more than that tho...
Old 10th January 2015, 12:36 PM   #6
mravlca's Avatar
Please elaborate why is it not good at all.
Old 10th January 2015, 01:59 PM   #7
Mihkus's Avatar
I couldn't call it a good design because:
Poor grounding, think and long supply rails, no HF filters on both chips, signal layout should be as compact and as closely together as possible and as far away from output and supply rails as possible and missing mute cap. I'm not an expert on this but just second opinion. Which is all true
BTW, have you tried your PCB's yet? I wouldnt risk. Chips wont blow up but they will oscillate for sure.
Old 10th January 2015, 02:06 PM   #8
Originally Posted by mravlca View Post
Why?
Because the way you have done it now, you get very poor channel separation.
Capacitors 4 sale! http://www.diyaudio.com/forums/swap-...ml#post3976369
Old 10th January 2015, 02:17 PM   #9
Best Regards,
Aleš
I guess because you would want the rf to goto ground asap. Thats why people solder a cap to the chassis input socket also, along with the resistance of the interconnect, it acts like an rf filter.
Old 10th January 2015, 02:19 PM   #10
mravlca's Avatar
You are clearly mistaken, PCB has excelent grounding because every components ground is routed into star point. Which HF filters you are reffering to, the ones on the input?
I could place components on the input better but hey this isn't bad also. Missing input cap doesn't make desing good or bad. I have one LM3886 without this mute cap for over 10years now and no turn on off pop noise is present.
Yeah I tried this PCB and no oscillations are present, no noises etc. and the sound is awesome. You are forgetting that this chip can work with very little amount of components stable.
Jig to help soldering SMD components tauro0221 Equipment & Tools 11 2nd November 2013 06:34 PM
Identifying 2 smd components sorenjepsen Parts 3 25th January 2012 12:30 AM
Identifying smd components pedefede Parts 2 6th January 2012 12:38 AM
use of SMD components? lanchile Solid State 7 26th September 2010 01:33 PM
SMD Components Iván Francisco Solid State 2 21st April 2007 05:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
