Question about powersupplies in integrated amps
Old 6th January 2015, 01:13 PM   #1
yaka24 is offline yaka24  United States
Default Question about powersupplies in integrated amps
Hi I'm planning on building a lm3886 but would like to include a phono preamp inside as well.
How can I handle the power supplies so I don't have 2 power cables plugged into the amp? I currently have a chipamp built with this transformer
Avel Y236503 160VA 22V+22V Toroidal Transformer
and will look to repurpose it in the new build. For the phono preamp I was thinking of something simple such as this: Velleman K2573 RIAA Stereo Phono Preamplifier Kit
which requires :
Specifications: Required power supply: 10~30 VDC regulated (not included) Current consumption: 5 mA (typical) Equalization curve: RIAA standard Input impedance: 47K Input signal: 5-10 mV PCB dimensions: 1-5/8" x 2-1/4".
Old 6th January 2015, 01:35 PM   #2
R.I.P.
Put the phono pre-amp as close to the TT arm exit as you can manage.
Then take the amplified output at "line Level" to a convenient volume control location and finally take that Buffered "line level" output to the Power Amplifier located at the Speaker's terminals.
regards Andrew T.
Old 6th January 2015, 02:31 PM   #3
I get that part of it.. My confusion is how I avoid having both an IEC Cord and DC Jack BOTH being plugged into the chassis.
Old 7th January 2015, 05:54 AM   #4
gmphadte is offline gmphadte  India
The DC socket has an integral leaf switch for such purposes, on the barrel contact.
Gajanan Phadte
Old 7th January 2015, 01:43 PM   #5
Sorry! I'm still a little confused....
SO I have to keep the power brick for the Phono Preamp inside the chassis? and use the integral switch how?
Old 7th January 2015, 09:07 PM   #6
infinia is offline infinia  United States
infinia's Avatar
I would add a little power supply regulator like this Series Voltage Regulator | Series Pass Regulator | Tutorial
use a 15V zener and a 60V npn transistor, connect the input to the chip amps + V rail at the big cap. and the output to the Vellman.
Old 7th January 2015, 09:46 PM   #7
infinia's Avatar
here a better pre amp than the Vellman requires 2 for stereo. Hi-Fi RIAA Phono Preamp
use a pnp transistor with the same circuit I linked to above to supply the -15 V.
Old 8th January 2015, 03:13 AM   #8
You have to elaborate the statement so that we understand clearly. More details, the better.
Gajanan Phadte
Old 8th January 2015, 01:01 PM   #9
This is very helpful. Thank you.
Old 8th January 2015, 01:10 PM   #10
Mooly's Avatar
Such a low current consumption means you can use a very simple shunt regulator (which has excellent performance) consisting of a series resistor and zener diode (of say 18 volts) to ground, fed from the chip amps positive rail.
Super simple and great performance.
Question about powersupplies in integrated ampsHide this!Advertise here!
integrated amps 100 per channel new2tubes2 Tubes / Valves 6 14th December 2011 06:11 AM
which NAD older generation amps & integrated amps are bipolar or mosfet? audionaut99 Solid State 3 21st May 2010 10:09 AM
Sony Integrated Amps leka Solid State 2 15th February 2006 02:34 PM
Major Noob question about powersupplies. Hybrid fourdoor Chip Amps 22 2nd August 2003 08:38 PM
pre+power amps vs integrated amps pkgum Solid State 4 22nd November 2001 01:46 PM
