ina217 mic pre schematic help - diyAudio
Old 22nd December 2014, 08:21 PM   #1
weroflu is offline weroflu  United States
Default ina217 mic pre schematic help
First project, trying to make a very small battery powered stereo mic preamp
-trying to keep the board small
-microphones are battery powered, unbalanced output, no phantom needed
-microphone impedance is 500ohms, max output .7V
-input/output on two 3.5mm board mounted mini jacks
-intended connection to a portable recorder, input impedance 22k
-ICL7660S with boost pin connected, hopefully will keep ripple unheard
-trying to keep this powered by a single 9v
-fixed gain of 10 (20db), might change to a trim later
I'm unclear on a few points:
-do I need input coupling caps since there is no phantom involved?
-since the input is unbalanced I'm unclear how to handle pin 2 on both ic's. I left pin 2 unconnected now on ic2 until I get some advice.
Thanks in advance for helping.
Old 22nd December 2014, 08:33 PM   #2
rayma is offline rayma  United States
Pin 2 should be grounded on both, not left open. The other inputs should have a proper load resistor to ground for the mics,
usually around 1k - 3k.
Old 23rd December 2014, 01:33 AM   #3
Also, both pins #5 should be grounded. These are part of the diff amp. The C3 and C6 are reversed.
Old 23rd December 2014, 07:52 AM   #4
Thank you Rayma.
Attaching revision with corrections.
Old 23rd December 2014, 03:35 PM   #5
Can I get away with smd 6.3v caps for c4 and c7 or do they need higher voltage rating?
Old 24th December 2014, 09:47 AM   #6
You are using 7660 for a mic preamp for negative supply...
I suspect it will be noisy.
Gajanan Phadte
Old 24th December 2014, 01:10 PM   #7
7660S
With the boost connected it is supposed to operate well above audible frequency, something near 60khz. Have you used the 7660S before or are you referring to the 7660?
Old 24th December 2014, 01:54 PM   #8
edit: more like 35khz, the Maxim 1044 might get near 60khz?? nominal frequency is 7-10khz, boost is 6 x nominal.
New Page 1
I'd like to know if anyone used the icl or max successfully with audio. If they are no good then time for redesign.
Old 25th December 2014, 06:34 AM   #9
Cleaned up the schematic.
INA217 Mic Preamp and its Capacitors Bamalama Solid State 0 19th November 2014 06:20 AM
Output Transformer for INA217 Mic Preamp? OrganicEffects Analog Line Level 5 29th October 2014 05:26 PM
INA217 Mic Preamp Spring Halo Solid State 10 13th November 2013 05:54 AM
Toroidal Transformer for 8 x INA217 Mic Preamp teleman Parts 14 26th October 2013 12:05 PM
Schematic for ART USB Mic Pre ? PB2 Solid State 1 23rd January 2010 04:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
