BTL LM3886 board/kit?? - diyAudio
Old 3rd December 2014, 02:33 AM   #1
Zero Cool's Avatar
Default BTL LM3886 board/kit??
Anyone know of a BTL LM3886 board or kit or one of those asian eBay boards/amps?? I cant seem to find one.
One I found on eBay listed as a BTL amp isnt. if you look at the board cloesly you can see the output is labeled + and GND and you can see the trace is connected to the CT of the power supply jacks and the Input ground so nope not a BTL....
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 3rd December 2014, 03:13 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Assembled LM3886 BTL 2.0 Power amplifier board 100W+100W-in Amplifier from Electronics on Aliexpress.com | Alibaba Group
A new scientific truth does not triumph by convincing its opponents ... but rather because its opponents eventually die, and a new generation grows up that is familiar with it. - Max Planck
Old 4th December 2014, 09:09 AM   #3
Zero Cool's Avatar
Thanks.that would work. I only need one channel but for testing that would work.
Old 6th December 2014, 05:12 AM   #4
ttan98 is offline ttan98  Australia
Becareful your speaker's impedance does not fall below 4ohm then power amp will fail.
Old 7th December 2014, 12:54 PM   #5
Zero Cool's Avatar
The load the BTL set up I am using it for would see would be about 12-20 ohms so a very easy load to drive even for a BTL amp.
Old 8th December 2014, 09:58 AM   #6
So each amp would see a 6 to 10ohms load.
That is not "a very easy load". That is about what a normal 8ohms speaker shows as a reactive load.
regards Andrew T.
2 LM3886 BTL advice Philfr Chip Amps 23 27th June 2014 11:33 AM
2x 85W TDA7294 BTL+Speakers protected Amplifier board Paladinxxx Swap Meet 1 16th March 2014 01:43 PM
DIY Hi-Fi Stereo Amplifier Board Amp 2 Channel TDA7294 BTL + Speaker Protection mit Chip Amps 1 7th February 2014 03:20 AM
Repacing the volume pot for lowergain for the TPA 3123 BTL board kp93300 Class D 1 7th January 2014 09:19 PM
Lm3886 in BTL mode with 4ohms load and Smps. Aucosticraft Chip Amps 63 15th November 2010 07:50 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
