strange chip???
strange chip???
Old 17th February 2004, 12:46 PM   #21
sparkle is offline sparkle
sparkle's Avatar
Hello again!
Well - finally I have finished it few days ago. Triple checked everything- everything was o.k. but when I power it up, nothing happened. The chip was dead- probably when the cover fell of something happened.
My girlfriend was very sad and I was not very happy because of the time put in..... Well back to the old drawing board. I have two TDA1514 chips so it is half way done now- hope this will work. TDA is easier to find if anything goes wrong- so, again, we'll be in touch.
Old 2nd November 2005, 04:24 PM   #22
sparkle's Avatar
Default 1000 times sorry guys....I just realized that
I didn't finish what I have started here.....
Te amp for my girlfriend was finished a week from the last post on this thread... it was made with TDA1514 like I said I will do....I will post some pictures.....
I managed to disconnect the part of the board of that old amplifier that was only amplifier itself so the logis went into my junk-yard...I used the amplifier part of the board and it worked instantly and very good. Unfortunately the voltage was little bit low but it works now also.... nothing happened till now.... everything fine....
sorry for the delay .... hope that You all that read this will foget me
daniel
Old 2nd November 2005, 04:26 PM   #23
sparkle's Avatar
another one
Old 2nd November 2005, 04:27 PM   #24
sparkle's Avatar
another
Old 2nd November 2005, 04:28 PM   #25
sparkle's Avatar
another (the old board that i cut in half to remove the amplifier part)
my girlfriend says that she is very happy with the amp
ps.s my friend Carlos .... i will tell You everything .....mp3...don't worry
Old 2nd November 2005, 04:32 PM   #26
sparkle's Avatar
another
Old 2nd November 2005, 04:34 PM   #27
sparkle's Avatar
and the last one
File Type: jpg 011105-my girlfriends amplifier010_resize.jpg (52.4 KB, 295 views)
Old 2nd November 2005, 04:37 PM   #28
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Now, that's one of a kind.
Congratulations.
/Hugo
Old 2nd November 2005, 09:20 PM   #29
sparkle's Avatar
thank you - i am sorry that it is a little bit late... i had probably another worries so i simply forgot to post feedback... i hope that everybody will forgive me
daniel
Old 17th November 2005, 08:15 PM   #30
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Hello Daniel Sparkle, i am doing an amplifier with the same chip
Not exactly the same...but a near cousin.
Mine is RSN3502N ..... well this "N" create a power supply voltage difference, this one can hold 40 volts simetrical and goes very easy to 60 watts undistorted each channel, when both are simultaneously driven.
Heat is big... bias current is high, and heatsink need to be very big...something alike 20 heatsink fins having 10 square centimeters each fin.
The internal protection is more kind than many others chips...as do not limit current...so...you have some twice this power instantaneous peak power, and this produces a very nice effect!
Quality is very nice, having worst midranges than LM3875 and better trebles and better dinamics.
Deep bass reproduction is almost the same of LM3875 not modified to increase of bass in extreme low frequencies.
We have to search for 15 volts somewhere or produce this negative 15 volts to feed pin 8.
The Chip uses a very strange AC information in the pin 6...maybe sensing voltage variations....it capture the signal from one of the power transformer secondary AC output (around 22 to 29 AC Volts)..... find a voltage divider that reduce the amplitude to 15 percent and feed the low impedance input in the pin 6.
Very interesting is that the chip is big...so, as a result, the input and output are not near.... this avoid a lot of compensations that normally result not good...also the enormous aluminium panel it has in its back (never flat, have to sand over a glass!) have area enougth to transfer a little bit more than 300 watts of heat...this way, produce 75 watts continuous each channel will not destroy the unit...voltage can be increased, input condenser increased and feedback line condenser can be increased too, resulting in 10 hertz reproduction without any loss of power.
Good luck to you....if want better sound...change to Mika.......as Mika sounds great!
ahahahaha!
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
strange chip???Hide this!Advertise here!
Strange Hum pftrvlr Tubes / Valves 4 20th February 2008 12:02 PM
strange chip UTC FM93 2822 NIC1138 Chip Amps 3 15th May 2007 02:59 AM
Brazil, and some strange laws, not too much strange! destroyer X Everything Else 0 11th September 2004 12:38 PM
Strange or what? Circlotron The Lounge 11 18th March 2004 01:28 AM
strange chip ????? sparkle Parts 1 22nd January 2004 05:04 AM
