Doubt in LM4780
Doubt in LM4780
Old 10th November 2014, 10:32 AM   #1
suneetha is offline suneetha
Default Doubt in LM4780
Hello,
I am using Fig.39 reference design for our Audio Amplifier application with a requirement of maximum 60W RMS Output from each channel.
To get 60W RMS Output signal how much maximum signal should I give at the input?
I have less knowledge on Heat Sink Selection?How to select the Heat Sink for LM4780?Instead of thermal compound paste,Can I use SIL-PAD as insulator between LM4780 and Heat Sink?
Suneetha.
Old 10th November 2014, 10:47 AM   #2
S4m is online now S4m  Germany
S4m's Avatar
LM4780 Gain Setting
Probably it will help!
Old 10th November 2014, 07:56 PM   #3
sfthurber is offline sfthurber  United States
Originally Posted by suneetha View Post
Hello,
Suneetha.
for the reference design a channel would need a bit over 1 volt RMS input to deliver about 60W into 8 ohms with a +/- 35 volt PSU (70 volts rail-to-rail).
Regards, Steve
Old 14th November 2014, 07:08 PM   #4
tomchr is offline tomchr  Canada
tomchr's Avatar
You'll probably get quite a bit out of reading the thermal design section of my Taming the LM3886 page.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 20th November 2014, 06:29 AM   #5
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
~Tom
Yes, that's good stuff!
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Doubt in LM4780Hide this!Advertise here!
4 x LM4780 mono, OR 2 x LM4780 stereo: Will I notice the difference? mondogenerator Chip Amps 23 1st November 2013 05:40 AM
Quick doubt about PSU for parallel LM4780 tent Chip Amps 17 10th July 2013 09:02 AM
Parafeed doubt croccodillo Tubes / Valves 6 9th August 2006 08:08 AM
doubt swaroopvg Power Supplies 0 1st July 2006 05:27 PM
