There is buzzing noise..Did i do anythng wrong with this set up? - diyAudio
Old 7th November 2014, 12:38 AM   #1
ng501 is offline ng501  United States
ng501's Avatar
Default There is buzzing noise..Did i do anythng wrong with this set up?
I am modifying this headset to bluetooth,
so i connect the battery to both bluetooth module and to the headset power ( i believe is for noise cancellation and amp),
switch the audio input from the jack to bt module,
ground both headset amp and audio input together and connect to battery neg-... and when i connect my phone to bluetooth there is buzzing sound coming out! it is fine when i use 3.5mm jack as audio source....
someone tell me put 0.1uf capicitor on both right and left channel between the bluetooth and the headphone driver can filter that sound....is that true or should i use a resistor instead?
Please help! Thanks!
Old 7th November 2014, 08:19 AM   #2
ng501's Avatar
any suggestion?
Old 7th November 2014, 09:19 AM   #3
danielwritesbac's Avatar
Any suggestion? Okay, here goes with that:
ONE ground wire, only one; because, there is only one ground.
Tools, Models & Software for DIYClipNipper boostLM1875 TurboPowerful TDA7293 kitTDA7294 pt2pt ♦ My post has opinion.
Old 7th November 2014, 10:01 AM   #4
ng501's Avatar
here is the orginal 6 cable
1)blue for the power positive
2)black for power nag-
3) copper for power ground
4) red audio right
5) green audio lefr
6) audio ground.
do you mean that two ground is a common ground?
so what is the best way to connect these to one battery and a bluetooth module with out the annoying buzzing noise??
Thankss
Old 7th November 2014, 11:36 AM   #5
Measure the resistance from one ground wire to the other ground wire.
It could be zero ohms, or it could appear open circuit.
regards Andrew T.
Old 7th November 2014, 05:30 PM   #6
ng501's Avatar
so where is the noise come from? im newbie,,,,,
Old 7th November 2014, 06:50 PM   #7
Is the battery more than 5v?
Old 7th November 2014, 07:39 PM   #8
Mark Whitney's Avatar
Can you tell us more about the headphones. Model, functions, voltage and how are they normally powered?
I think the blue device is a TP4056 1A Li-Ion battery Charging Module. Not bluetooth.
Did you measure any the voltages and are they correct for the headphones?
Regards Mark.
Old 7th November 2014, 11:18 PM   #9
ng501's Avatar
the battery is 3.7v, headphone is a beats studio v2.
the pic i upload is the original set up with the battery and 4056 charging module and 3.5mm jack. it works well with no noise.
However, after i add the module from here
http://www.amazon.com/gp/aw/d/B00AND...&robot_redir=1
it will get a buzzing sound. Again, this module running when i only use the 3.7v battery above and connet it to other speaker.
the problem comes when connect the headphone power, battery, bt module and audio in all together.
some people suggest it is a ground loop problem becoz i use the same power souce for both the bt module and the headphone amp.
thanks for.you guys help!
Old 7th November 2014, 11:20 PM   #10
ng501's Avatar
yes the battery voltage is fine and i have no problem when i only run it on the 3.5mm jack...just has problem when its connect to the bt module.,.
New to forum - Buzzing noise 83462j Solid State 8 21st March 2014 08:06 PM
Whats wrong with my set up? blackgu1tar PA Systems 9 22nd June 2013 03:25 PM
Bat VK3i buzzing noise alexIG Tubes / Valves 6 28th February 2009 09:19 PM
Buzzing noise Puffin Subwoofers 2 1st August 2006 08:35 AM
My amplifier makes a buzzing noise Jimmy154 Solid State 7 25th October 2002 05:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
