BPA200 VU LED - diyAudio
Old 4th November 2014, 09:44 AM   #1
Default BPA200 VU LED
Hi to all;
newbie here;
I just Finished my DIY BPA200, and I planning to add VU LED.
I have some question:
The output of BPA200 is two, the non-inverted goes to positive side of the Speaker while the Inverted output turn to Negative side of the Speaker.
The input of VU-LED is IN- GROUND(gnd)
Q1:Can I connect the VU-LED the same as the speaker?
thanks
Old 4th November 2014, 10:04 AM   #2
Mooly's Avatar
You must connect the input of this VU to one output (either the plus or minus) and connect the ground of the VU circuit to the ground of the amp.
As the VU runs off a dual rail supply you must make sure that C2 is correctly polarised in use. You could even replace C2 with a film cap (something like a 1uf) and increase the values of R1, R2 and TR1 by a factor of 10.
Installing and using LTspice. From beginner to advanced.
Old 4th November 2014, 10:04 AM   #3
Did it Himself
richie00boy's Avatar
Connect the VU meter to one side of the amp output only. It must be grounded.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more.
Old 4th November 2014, 10:15 AM   #4
Thanks for all response,
Thats what I thought.
Noted: God Bless
VU LED - looking for drivers Steinberg Construction Tips 11 8th July 2012 07:07 AM
Passive LED VU meter adannel Parts 1 31st August 2010 06:58 AM
LED VU meter question scwhiteley Everything Else 3 14th April 2010 12:29 PM
LED VU meter neil_kaye Parts 8 27th December 2006 08:43 AM
led vu meter leander Solid State 3 22nd September 2005 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
