LM 3886 Hum
LM 3886 Hum
Old 28th October 2014, 12:21 AM   #1
bluemike is offline bluemike  Canada
Default LM 3886 Hum
Hi Guys
I turned on my amp and got a hum from my speakers with no load
I put a multimeter on the speaker outputs and it measured 3 volts ac
I quickly unplugged the amplifier
Does this hum do damage to your speakers
I was told that the ic had not stabilized and this is the reason for the hum until it reaches operating temperature
does this make sense
I have since added a timing relay to the disconnect switch of my lm 3886 amplifier to prevent future mishaps
Have I done any speaker damage no dc was present
Opinions appreciated
Old 28th October 2014, 01:27 AM   #2
rayma is offline rayma  United States
Originally Posted by bluemike View Post
Hi Guys
If this was 60 or 120 Hz it was at about 1W according to your meter, so probably the woofer is ok.
If it was hf oscillation, the tweeters could have been damaged.
Old 28th October 2014, 02:02 AM   #3
How can I tell if it's hf oscillation
The volume was at zero
Old 28th October 2014, 02:24 AM   #4
There's no way to be sure. You can check the tweeters. If you have an FM tuner, turn off the muting and listen to the hiss at a moderate level.
Or, use a web white noise source. You should be able to hear high frequencies easily, especially on the axis of the tweeter.
Old 28th October 2014, 02:43 PM   #5
R.I.P.
Have you worked out why you had 3Vac on the output?
BTW,
It had nothing to do with warm up time.
regards Andrew T.
Old 28th October 2014, 02:58 PM   #6
Originally Posted by AndrewT View Post
Have you worked out why you had 3Vac on the output? Cold solder joint
BTW,
Old 30th October 2014, 06:57 PM   #7
R.I.P.
No comment?
regards Andrew T.
Old 30th October 2014, 07:42 PM   #8
No comment?
Sorry it was a cold solder joint that was going
My tech said because I have a tube pre the tubes need to warm up if the valves are not stabilized and you turn the amp on you will get a hum that goes through the speakers
LM 3886 HumHide this!Advertise here!
lm 3886 larryg Chip Amps 6 1st June 2009 06:38 PM
LM 3886 bridged costy_ro Chip Amps 40 28th April 2006 12:05 PM
LM 3886 Tips... -_nando-_ Chip Amps 39 10th January 2006 06:27 PM
