| Chip Amps Amplifiers based on integrated circuits |
#11 |
I just did as suggested and put a pair of 1000uF caps right on the pins of one channel of my amp to see try and get rid of the hum. It didn't work. It still has the same hum as without the cap right on the pins. I'm thinking either the noise is radiated from the torroid, or maybe I'm getting some noise injected from how I have the LED's wired. Right now the wires to connect the LEDs to the power supply cross the AC lines, so maybe some noise is being induced. Anybody got any other ideas? I really thought the caps would take care of it for sure.
#12 |
however when it comes to hum I have had my share !!!!!
Something that has ALWAYS been the source of humm in my gc's (3 so far) is a bad ground loop or an bad iec receptacle that let not ground go through ..... You might wanna check that and one last thing, you wrote that the toroid is more than 1000 VA wow..... so it is more that 50 Ampères ???? I would suggest trying a smaller toroid for that matter, but you dan't need to take my word for it, check it out with other participants here. J-P |
#13 |
Hi Dustin;
Nice work! On the hum issue, did you use shielded cable on both the inputs and the outputs? I've found that to be the key to reducing hum over here....sorry to ask a dumb question if you are using shields, but my middle aged eyes couldn't tell from your pics if you were.... Good luck and all the best! Morse |
#14 |
Hello, i'm not very familiar with the gainclone, but noticed that you're using a fairly large toroid for your transformer.. How much output power does your particular amp put out? Also, would this amp be able to be driven by a passive preamp?? TIA
Dave |
#15 |
uvodee --Thanks for the suggestions, I'll be sure to check the IEC and my star grounds again. I'll try bypassing the IEC and see if it helps.
Morse-- No shielded cable, just a couple strands of regular CAT5 twisted together. bonsai171-- The torroid is way oversized for this amp, but I'm probably going to add more channels to it. Each LM1875 is only good for ~20W. But that's plenty for my use. I'm not using any active preamp. Just a pot and the input cap between the amp and my CD player. Check out Nuuk's site some folks made some awesome GC's with valve buffers. |
#16 |
Well, I'm quite embarassed to admit this but at least I found out why my amp was humming. It wasn't even the fault of the amp. The RCA cable coming from my volume pot to the amp was picking up noise. I realized it wasn't the amp when I unplugged the input and the hum went away. I can't believe I didn't try that earlier, but at least I know now. Thanks for all the suggestions everybody, I appreciate the help!
#17 |
Hi Dustin;
Glad to read that you've got the hum issue pinned down! Finding the source for that kind of thing can be a genuine pain.... >>>...RCA cable coming from my volume pot to the amp was picking up noise...<<< You might want to check both the cables and the volume control independently. Don't know if you've built your own IC cables before, so please take no offence if you already know this, but you can build some cheap but good ones that are good at noise rejection by using shielded microphone cable. Just connect the shield to the cables ground lead at the source end and leave it floating at the amp end. It works. Just my 2 pence here, but here's my recipe for "cheap but good." Go on over to Parts Express and get some of their 39 cent a foot "Professional Microphone Cable" (I bought a 100 foot reel of it - I use it that much....) and their "Dayton" brand gold plated RCA connections. Maybe not "high end audio", but it marginally outperforms Monster IL400 MK II's IMHO (I've got several pair of those...) for about 1/4 the price. Good luck and all the best, Morse |
| FS: Radioshack 8" fullrange | thedanielm | Swap Meet | 7 | 11th June 2007 10:54 AM |
| What to do with RadioShack 40-1041? | Spasticteapot | Full Range | 0 | 14th October 2006 09:14 PM |
| FS: used radioshack 3-amp DC power supply | jrsun | Swap Meet | 0 | 5th September 2005 09:52 PM |
| Dr.Bose and Radioshack.. | Bose(o) | Multi-Way | 7 | 1st January 2003 07:43 PM |
| WTB: Radioshack RS 40-1354A | psarin | Swap Meet | 1 | 5th April 2002 08:31 PM |
| Page generated in 0.11758 seconds (66.00% PHP - 34.00% MySQL) with 11 queries |
