Old 19th January 2004, 10:52 AM   #1
jimbeam is offline jimbeam  Germany
Default TDA2050 Input Sensitivity
Hi everybody!
I'm currently working on a DIY guitar amplifier using the TDA2050 chip, but I'm not sure about the signal level that should be provided to the chip.
The Datasheet does not mention input sensitivity anywhere, so I'm a bit clueless...
Can anyone help me out?
Old 20th January 2004, 06:31 AM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
The input sensitivity is set by the the gain used in the circuit. If you can provide a schematic, we can help you out.
Mads K
Old 20th January 2004, 09:00 AM   #3
The datasheet contains a suggested setup for the chip right on page 1, which I plan to use.
The amplifier will have a preamp section with tone and volume control, the tone section will cut around 6dB from the input signal, at least that's what Electronic Workbench is telling me.
If this was a normal opamp, the gain in this circuit would be 1 + (22K / 0.68K) = 33.35, and that's about 30dB, right? Now how does this determine the maximum input signal? I want to avoid overdriving the chip by all means, it's not a tube amp!
The TDA2050 will be supplied with +/- 21V, if that helps...
Thanks for your help!
Old 20th January 2004, 01:18 PM   #4
Mad_K's Avatar
Then, max input is +/-15V as per page 2 on the datasheet
however, it only takes 0,6V on the input to clip the output.
hint: read LM3875 datasheet, it is all explained nice and easy there (page 14).
edit: it is a normal opamp, your calculation is correct.
Mads K
Old 20th January 2004, 08:56 PM   #5
That's a good read, not just the usual curves and tables!
Since the signal is attenuated by the tone stack to about half its original level, the output stage will see a few hundred mV at full volume setting, so there should be no problems with clipping.
Thank you for your patience!
Old 25th October 2010, 07:10 PM   #6
Mashoni is offline Mashoni  Germany
Send a message via MSN to Mashoni
is there a bridged circuit schematic for a TDA2050 chip out there since there was none on the datasheet.if anyone has please do me a favour and post it please thank you
Old 27th October 2010, 09:27 AM   #7
ampimp is offline ampimp  United Kingdom
Banned
I would guess that bridging 2050 is much like bridging any other power op amp. Just stay in the soa of the 2050 and you should be ok.
Regards Ian
Old 27th October 2010, 12:02 PM   #8
bridging a current limited chipamp falls into the trap of ending up with an amplifier that can only perform well into high impedance loads.
regards Andrew T.
Input sensitivity on amp? suspencefull Solid State 25 3rd September 2006 07:44 PM
What is input sensitivity? boxedin Solid State 15 29th December 2005 08:04 PM
Son Of Zen Input Sensitivity rutcho Pass Labs 3 30th November 2003 03:46 PM
BOZ input sensitivity gema Pass Labs 0 29th July 2002 10:55 AM
input sensitivity [SoZ] Phage Pass Labs 2 21st January 2002 04:07 AM
Page generated in 0.10494 seconds (70.29% PHP - 29.71% MySQL) with 10 queries
