| Chip Amps Amplifiers based on integrated circuits |
#11 |
#12 |
If any is curious about the Tube Cad Journal article the circuit was mentioned in it was here: http://www.tubecad.com/index_files/page0023.htm
-Tom |
#13 | |||||||||
Previously: Kuei Yang Wang
Konnichiwa,
Once you talk different systems, implementations, passive parts etc you cannot any long draw valid comparisons. If you like an IGC with valve buffer, with LPF or without, inverting or not, if it sounds good to you, have fun and more power to you. I did not criticise your design, I merely pointed out a few things I feel may make an audible change. Just like I feel that virtually ANY Op-Amp sounds better inverted, all else being equal. You don't HAVE to try it, but you asked opinions. Those I gave where mine. Quote:
Sayonara |
#14 | |
#15 |
Hi there,
I would love to hear whether there have been any further insights/improvements in the last years regarding valve-buffered gainclones with current source ? See my design at the start of this thread. I see one design published which uses a JFET as a current source, see Option 3 by Maarten here: Tubeclone 2 It appears to me that many of the gainclone afficionados dont try designs with tubes due to the extra challenges involved. Also the valve/tube guys do in tendency not get involved with opamps. Unfortunately this limits somewhat the further development of such hybrids. Which is a pity IMO because such designs can deliver really great sound for little money. Cheers Gerry |
#16 |
I've used tube input stages with some power amps including some chip amps.
The listening tests showed me that I cannot automatically assume that adding a tube front end is going to make the amp sound 'better' or 'nicer'. In some cases it was better sounding but in other systems it did strange things like 'sanitise' the sound. What was VERY dynamic in the bass end was converted to just ordinary sound. By ordinary sound I mean the sound we hear from many average systems which are 'nice sounding'. Component changes didn't improve things. The only way you can determine how it will sound ' in your system' is to try it out. I'm almost convinced that no one else can give you an answer that would apply exactly for your system. But yes, it "could" make a big difference and unfortunately you will have to try it out yourself to find out ! If it doesn't , don't be disappointed . There will be other combinations which might get you what you want in your system. It would mean that you have just reached a major junction on your long DIY ride ! But there is a LONG way ahead with probably some more great junctions on the way!
AM |
| Valve buffered IGC - volume pot causes DC offset, crackling | gaplessophile | Chip Amps | 29 | 3rd July 2009 01:02 AM |
| Tube-Buffered Gainclone | sorenj07 | Chip Amps | 10 | 1st June 2008 07:07 PM |
| Diode bridge for Valve Buffered GC | falcott | Tubes / Valves | 3 | 5th November 2006 03:35 AM |
| Valve buffered GC project | Lilja | Chip Amps | 5 | 11th August 2005 07:00 AM |
| valve buffered gainclone questions | moonshow | Chip Amps | 1 | 10th July 2004 09:31 AM |
| Page generated in 0.12974 seconds (88.35% PHP - 11.65% MySQL) with 11 queries |
