| Chip Amps Amplifiers based on integrated circuits |
#121 |
I would gladly put the files on, except right now I dont have access to them! I may, in a few weeks (once I get my new computer :-) They're locked up on a hard disk right now.
#122 | |
wassup with the files? still locked up? please post it... spread the good word... ~M. |
#123 |
Sorry I didn't post it all this while. To make up for it, I spruced up the schematic a bit, and made it more readable. Please remember this is not the most Hi-Fi of amps, and one cannot expect wonders of the LM1036. The LM412 is just a suggestion, feel free to use any dual opamp of your choice (reasonable bandwidth, please! Dont use 250 MHz CFB types
), or even bypass it altogether to reduce the cost.I made one small mistake with this design, the tone control inputs go first to a 100nF cap, then to a 47k resistor and to the LM1036. The cap should actually come in *after* the resistor, this way any scratchiness due to old pots will be cancelled. You can do this by soldering SMD 100nF caps (or through-hole types, if you're needlessly scared of SMD) to the underside of the board, between the cap pin and the nearby ground island. Please let me know if there are any problems with opening the ZIP file, they were made using gzip (Linux fanboy now )Please pay attention to the external wiring of this board, the star ground is *not* on the board, it's at the PSU filter cap junction. I will not repeat this again to the next brightspark who decides there's something "wrong" with the board. |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 07:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 06:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 12:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.20990 seconds (33.74% PHP - 66.26% MySQL) with 11 queries |
