4xLM3886 fuse blow-out - diyAudio
Old 10th September 2014, 05:01 PM   #1
Default 4xLM3886 fuse blow-out
what wrong with this schematic?
I found this diagram to this forum site:
w w w .elab.ph/forum/index.php?topic=45229.40
the thread starter also put a link for pcb
w w w .4shared.com/file/yMDRO11oce/bpa200.html
I follow everything but I guess there is something wrong.
I recheck the pcb and I'm 100% sure that there's no shorted traces.
I put 5A fuse and it's always blow in a negative side of the rail.
Old 10th September 2014, 07:15 PM   #2
ericj is offline ericj  United States
ericj's Avatar
I don't see anything wrong with the schematic but the power supply isn't shown?
That file sharing site is annoying and i'm not going to log into it to download the pcb info.
Double check that you installed all parts correctly.
See if the psu alone blows the fuse with just a dummy load.
Old 10th September 2014, 07:38 PM   #3
AndrewT is online now AndrewT  Scotland
Is this another Member that does not understand how a SINGLE chipamp operates and yet he/she jumps headlong into a multi-chipamp implementation?
Why call it a 4x3886 when National's name for it is BPA200?
regards Andrew T.
Old 10th September 2014, 07:39 PM   #4
Please attach pics.
regards Andrew T.
Old 10th September 2014, 08:05 PM   #5
I attach the power supply I used and the schematic.
Old 10th September 2014, 08:40 PM   #6
Art M is offline Art M  United States
The +15V/ -15V have no reference to ground as shown on the schematic ? If you are going to run the OpAmps with a single voltage of 30V, you are going to need to bias the OpAmps with additional parts and use AC coupling capacitors ?
Old 10th September 2014, 09:26 PM   #7
mzperx is offline mzperx  Hungary
Try to remove components C4,C8,... in order to deactivate the Mute function. During the muting the servo loop is broken and the outputs of opamps can rich opposite voltages to force current between LM3886 after stepping out from mute mode.
It's better to not apply the delayed muting in case of parallel tied setup, because the timing can be an issue between chips:
https://docs.google.com/file/d/0BzbI...w4MG5jQWs/edit
On the other hand the resistors seem to be too high value around the NE5534s otherwise use JFET input opamp or bipolar type with bias current cancellation.
Old 10th September 2014, 10:35 PM   #8
kevinkr's Avatar
The power supply ground is on J2.
I question the need for the DC servo circuitry at all, the offset of the 5534 with a 2.2M input resistor is going to be a lot worse than the LM3886. The 5534 is not unity gain stable and probably needs to be compensated for integrator use. If you want to use the servo choose a low offset fet input unity gain stable op-amp instead. (It does not need to be fast)
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 11th September 2014, 02:14 AM   #9
do you mean sir I try to remove all mute caps c4,C8,c12,c13.
I have also doubt with the NE5534s
Old 11th September 2014, 02:39 AM   #10
thanks to all response...
try to test again, I remove the ne5534 and the fuse dosn't blow-out but there's an a "zzzz...." sound on the board. and also base on the data-sheet of ne5534, 5534 is Fast opamp NE5534 10mhz than opa134 8mhz. the problem is opa134 is not available in the Philippines.
any good substitute?
Did i blow a fuse ? or would this work ? jan_stevns Multi-Way 0 23rd June 2014 06:39 AM
fuse blow milosus Solid State 1 6th December 2012 11:40 PM
New 'lytics blow the fuse glorocks Parts 13 4th June 2009 02:54 AM
Sa-5.1 blow fuse jpweaner2 Tubes / Valves 0 3rd May 2007 01:36 PM
Fried a slow blow 4 A fuse chris ma Everything Else 2 10th October 2003 06:59 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
