2ohm
i didn't found any 12-0-12 powerful transformers so i think of connecting two toroidal 12v and 70 VA transformers together ,what do you think of this.
Another question with 2ohm will the sound quality of output would be the same as with 4 ohm .If somebody tried that with another amp please write.
If the two transformers are identical then you should be ok to connect them in parallel, watch your phasing of the windings though !.Sound quality should not suffer but at the end of the day its subjective, one mans meat'a another mans poisen.
Jez.
