| Chip Amps Amplifiers based on integrated circuits |
Anyone know where I can find ganged (2, 4, or 6) gold RCA panel jacks that are mounted on a piece of plastic with two screw holes for mounting on a panel?
The 3/16" thickness of most of the singles doesn't help me much. I am building a GC enclosure out of solid oak. My walls won't be very strong @ < 3/16". (Like my headphone amp, linked here ![]() My new baby If anyone knows of any deep-mount singles, that'd be cool, too. In a pinch, I suppose I could make them. But I am not very good at plastic/metal work. What I am looking for is just like the "dual RCA jack" at the bottom of the link, but with better quality jacks: http://www.wytekdirect.com/Audio/rca..._and_jacks.htm Muchas Gracias. GnD
I had the right to remain silent. I just didn't have the ability. (Comedian Ron White) |
#2 |
Hello Grahamn;
I've run into the same problem ("short" components with thick wood chassis) and now use 1/8" thick aluminium sheet stock as "mounting plates". Just buy some 2" wide (or 3" wide or whatever) stock and cut off the right length with a conventional saw and mitre box. Then round the corners using a file and drill holes using a punch to establish centre and a conventional power drill (you do need to clamp the piece down to a scrap piece of wood - otherwise it's got a tendency for the drill to "screw it's way through the wood", which makes it hard to control). Don't know if this is what you're after, but it's just a thought. Good luck with it! Ja mata, Morse |
#4 |
Thanks, guys!
Both excellent ideas. Nice tube amp, Morse. What is it? Nice woodwork, too. And that Neutrik jack is damn-near perfect, Dhaen. I am gonna case my IGC in oak -- and just found a wonderful pair of Fostex 103-based full-range birch-plywood speakers last night that I now have the hots for. http://home.hetnet.nl/~geenius/Solo103.html This guy has about a dozen projects online and does beautiful work. I love this hobby. GnD
#5 |
It's in sweden so the cost might be too high, but i bet you could find something similar in your parts too:
Gold-plated female socket for PCB mounting BTW:It says gold-plated, but the picture looks more like nickel or something to me... (ELFA has for the most part pretty good stuff, so maybe it's just the photo). /Andreas |
#6 | |
They are gold plated, but are not very suited for thick panels...
Mads K |
#7 |
Hi Grahamn;
>>>...Nice tube amp, Morse. What is it? Nice woodwork, too...<<< Thank you. That's the Gnat, a 6BM8 miniamp I built a while back. It's got about 3 wpc, and cost a bit over $100 in it's current configuration; the biggest limitation is the poor bass response due to the cheapie output trafos, but I plan a nicer version with better iron. You can see pics of some of my other amps at my site: http://home.earthlink.net/~shidenkai/index.html It doesn't include pics of any of my chip based headphone amps, or the TDA2030A that I (finally) got working about 10 minutes ago. That's playing in the background now on it's breakin trials and Gary Puckett and the Union Gap sound just fine..... >>>...and just found a wonderful pair of Fostex 103-based full-range birch-plywood speakers last night that I now have the hots for...<<< Aha! A man of taste....the Fostex's are my current fave drivers - they represent a truly awesome cost/performance ratio. If you've not heard the FE103E, give it a chance to break in a bit before you judge it. All the Fostex's that I've worked with have needed considerable breakin time - but it's worth it. Expect the midbass to be a little lean at first, but that's normal. And of course you can't expect the deepest bass from a 4" driver...but do expect some really incredible vocals and a sound field with some depth to it. Good luck on your projects! All the best, Morse |
| Source for Gold plated Bayonet Panel Fuse holders? | jstang | Parts | 0 | 26th April 2009 07:23 PM |
| Source for Gold plated Bayonet Panel Fuse holders? | jstang | Solid State | 0 | 26th April 2009 07:22 PM |
| Gold plated jacks to... | johnferrier | Everything Else | 1 | 21st December 2003 05:09 AM |
| DIY silver RCA panel mount jacks | tom1356 | Everything Else | 4 | 1st August 2003 05:43 PM |
| Gold on copper RCA jacks | Prune | Parts | 6 | 6th June 2003 05:42 PM |
