Lower gain, higher input impedance gainclone - diyAudio
Old 20th August 2014, 12:58 AM   #1
dimkasta's Avatar
Default Lower gain, higher input impedance gainclone
I have been using a LM3875 Gainclone for a few months now and I am very happy with it.
I am running it at ~26V (18VAC secondaries) for a conservative power output with both my 93db 8ohm and 92db 4ohm speaker sets.
I am following the usual schematic more or less, with additional 10000uF caps for extra bass.
What bothers me is the lowish input impedance that is forcing me to use big and lower quality coupling caps with my DCB1 (on top of being a harder load), and the fact that I have way more gain than I need in my room (trying to also perhaps reduce the effect of the pot in my dcb1)
What I am considering, is to actually increase the input impedance to 100K and reduce the gain to around 24dB
With R2 at 100K (no pot, driven directly by dcb1), R4 is also 100K to minimize dc offset, and for ~24dB gain, R3 is ~4.3K
From what I can tell from the datasheet, operation should be well below the spike trigger point
This would allow the use of a very nice quality 0,47uF coupling cap (teflon or something). But I am also considering to remove the coupling cap after DCB1, and instead use a 10uF feedback shunt to zero DC gain where the effect of the cap will be compensated by the fast feedback operation.
Finally, I am thinking of going further to 200K input impedance (like my previous electrocompaniet amps) and/or try to replace the "spiked" 3875 with its small brother 1875, but I would probably have to reduce the voltage a bit to keep it in safe operating regions.
I have tried to read a lot and study the datasheets, but I am still pretty novice in chipamps and opamp operation theory, so any feedback would be greatly appreciated.
Second harmonic and semi-sweet wine for everyone...
The DIY Tone! | Shigaclone
Old 20th August 2014, 02:10 PM   #2
<< What I am considering, is to actually increase the input impedance to 100K >>
Nothing to it. You're talking about a buffer, which is long-mature technology.
The whole purpose of a buffer is to separate an audio source from a following circuit. In essence source sees no load at all.
Connected with 100% feedback as shown, most op amps become a buffer. The characteristics of a buffer are unity gain, extremely high input impedance (in the tens of megs or higher), and extremely low output impedance (single digit). Distortion is negligible, in the three-decimal range.
I've posted a circuit below. It looks a bit lopsided because it's actually an el quickO edit down from a larger circuit, edited down to what I think are your needs.
The input circuit is a rip from Douglas Self. R1 and C1 shunt noise to ground. C2 and R2 are, of course, a high-pass filter.
R3 is a just-in-case resistor to prevent oscillation. It theoretically does nothing, since there's theoretically no current flow.
R4 reduces volume as you wished. It forms a voltage divider with your existing 10k input pot, and simply dissipates half the input signal. True this is wasting half the input, but it's no different from keeping the volume turned down. The 10k value is a guesstimate on my part. Maybe 5k?
The circuit is shown as direct coupled (no output capacitor) because output errors are expected to be insignificant. Another guesstimate.
With a 100k Zin you're well into Johnson noise territory, and noise can become a problem in general. You might want to consider reducing R2 to 56k or thereabouts. You could leave C2 at 0.33uF, or adjust it as wished.
Component specs are simply what's commonly available on eBay. Of course you can go higher and tighter if you like. Other ICs could work (no guarantees which will or won't), but I doubt there'd be any real improvement.
Hope this might be of some interest.
File Type: jpg IC - NE5532-buffer-preamp_01_k_special.jpg (105.1 KB, 136 views)
Old 20th August 2014, 03:02 PM   #3
dimkasta's Avatar
Thanks a lot for your effort
I am not talking about an additional buffer (I already have a dcb1). I am talking about adjusting the gainclone for bigger input impedance, so that it is an easier load for everything (including buffers) and allow for a smaller coupling cap.
About further cutting the input signal, if we already cut it with a pot, there is no need to cut it again with an additional divider. I wanted to reduce the gain so that a smaller part of the pot is in series with the signal.
About the noise, I have read a bit about it with bigger resistor values, but I have no opinion on when it happens. I will consider your suggestion for ~50K which should make a nice difference anyway.
Old 20th August 2014, 03:11 PM   #4
<< I am not talking about an additional buffer (I already have a dcb1). >>
I have no idea what a dcb1 is, but hey, noprob.
Old 20th August 2014, 03:11 PM   #5
jcx is offline jcx  United States
you can put a buffer after the volume pot, going directly to the chip amp input
you could find a op amp with a decent Vos spec so that it can be DC coupled to the chip amp +input
or even better, rewire the chip amp for inverting gain
you need to use compensation tricks to safely reduce the feedback determined gain - these chip amps all have high minimum gain settings for stable operation
inverting operation makes the noise gain compensation easier too if still need to reduce gain
Old 20th August 2014, 03:34 PM   #6
dimkasta's Avatar
From what I remember 20db is the minimum recommended gain for that chip implementation, so 24dB should be pretty safe from a stability point of view.
About the buffer, again I am using a salas DCB1, but I am using it AC coupled for extra safety because it is really hotroded
Old 20th August 2014, 03:50 PM   #7
I'm not into cute named "guru" projects - just suggesting what would be easy, more accurate
Old 20th August 2014, 05:10 PM   #8
dimkasta's Avatar
Lets not further analyze here if Nelson Pass or Salas is a guru in quotation marks with cute named projects.
Lets just say that my first stage buffer works very well and I do not want to (not to mention cannot) build and optimize a new opamp stage to replace it.
Lets just say I just want to optimize a bit my final amplifying stage to make it an easier load and decrease its gain, choosing values very close to ones suggested on the datasheet itself.
Any comments on the changes I proposed ?
Here is an updated schematic to make things clearer on what I want to work with.
So far I am keeping the warning about noise from the 100K resistors.
Old 21st August 2014, 07:50 AM   #9
Mooly's Avatar
Non of these are ideal solutions.
You now show a 100k input impedance and a 4.3k feedback return. That is probably going to create a significant DC offset unless you now AC couple the 4.3k to ground. Keeping feedback and input resistors the same only works for DC offset when the feedback return is AC coupled.
Noise from the 100k input resistor isn't such a problem because it is shunted by the preamp output impedance.
There is no easy to achieve what you want without a redesign I'm afraid.
Installing and using LTspice. From beginner to advanced.
Old 21st August 2014, 08:20 AM   #10
dimkasta's Avatar
I was thinking to add the shunt capacitor. 10uF in series between R3 and earth
Input impedance, the higher the better or not? tingtong5 Tubes / Valves 1 30th May 2011 11:14 AM
Lower closed loop gain? Higher slew rate. fotios Solid State 4 27th July 2009 02:41 AM
What is the desired lower -3db cutoff and input impedance? CJ900RR Chip Amps 5 12th February 2008 12:59 AM
Lower rails for lower impedance? 95Honda Solid State 7 19th December 2007 09:59 AM
Need enlightments on GainClone input impedance and volume control Elkaid Chip Amps 10 8th April 2004 08:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
