Project Box to enclose a Sure TA2024 - diyAudio
Old 17th August 2014, 12:54 PM   #1
Default Project Box to enclose a Sure TA2024
Hi folks, this is my first post and my first project.
I just ordered a Sure TA2024 board from E-Bay. Now I need to find a box to enclose it. The purpose of this project is to drive a pair of old (but really neat looking) Apple Pro "eyeball" speakers. So this box will sit on my desktop and will receive input from my PC and will output to these speakers.
I suppose I could have ordered the pre-built version of this already in it's enclosure, but I'd rather do it myself.
I'm really new at this, so I'd like some advice. Is there a project box that is the right size and has standoffs in the right location to mount this?
If not, then how do I go about finding the right size box and how do I mount this properly?
The dimensions of the board are 3.6 inches x 2.7 inches, as per the Product Manual. The distance between the mounting holes are 3.2" and 2.3".
I suspect I'll want to let the RCA inputs that are on the board poke out through the side of the box... but if necessary, I'll mount additional hardware on the box and wire it up.
Old 17th August 2014, 01:55 PM   #2
picowallspeaker's Avatar
Hi, generally amplifiers and their PSU are in the same box, this allows for very short connections between them. So I suggest to remove the jack female plug for +Vs and solder directly the wires from the PSU cap. The same can be done for the two RCA plugs, but this for allowing reliabilty for the traction when inserting and disconnetting the plugs, so the new (ISOLATED from the chassis) RCAs can be fixed onto a panel.
Edit...oh, I see that there are also screws for PSU connection!
Old 19th August 2014, 01:57 PM   #3
I think you want a nice looking setup, so I actually hesitate to suggest this thread. Still, it might jog your thinking, so here it is, starting at post #7. Recommend a cheap (<$50) amp?
The standoffs used to mount computer motherboards work very well for printed circuit boards (since that's what motherboards are, after all). Search eBay for "motherboard standoff" If you're willing to order from Asia they're cheap, really cheap.
I've use thick (3/4") weatherstripping and hot glue to mount perfboard. CAUTION: do not get hot glue on components. It runs at something like 300 degrees F, which is a wee bit out of spec.
Old 22nd August 2014, 08:20 PM   #4
Bare is offline Bare  Canada
Good place to start
Would be the Chip Amp photo gallery !
Gig In A Box project Wolfe32 Digital Source 1 12th June 2013 01:09 AM
What do you guys use to enclose your amps? Fusion916 Solid State 15 15th September 2012 08:55 AM
TA2024 Custom Box Help Needed bairda Class D 2 1st June 2012 12:23 PM
ground in project box. qweetz Parts 10 17th April 2012 03:15 PM
AMP/BOX PROJECT! fouchagalaga Class D 2 22nd January 2011 12:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
