hum in DIY amps, TD7293, PCB - diyAudio
Old 3rd August 2014, 11:06 AM   #1
Default hum in DIY amps, TD7293, PCB
Hi all,
I found this forum via this thread 50 Hz in home made power amp and read the linked thread as well.
Now, here is my troubles: the amplifiers hum a little bit with nothing connected, if I close their inputs to ground, the hum is gone.
The hum gets worse, if I connect the amplifiers to the crossover. When I disconnect the signal cables from the crossover, but leave them on the amps, it gets worse again. So far I twisted the signal cables (as I got good experiences noise wise with twisted pair cables in another application).
the power supply
the crossover
the amp
amp schematic
amp PCB
could the Molex conns be the problem in the amp? Or where GND jumps at the jumper J1 and gets to pin 4 SGNGND of the TDA?
thanks for your help!
Old 3rd August 2014, 11:53 AM   #2
50 hz humm is usualy a ground loop issue.
examinate the amp and the crossover connected as a whole unit for possible ground loops.
Old 3rd August 2014, 01:04 PM   #3
I disconnected everything from the amps, still get the hum.
The ground meets on a reference point on the chassis, not on the power supply. There is 3 power supplies, one for the crossover, one for the amps and one for the delayed switch on of the amps, they have a green wire to that chassis point as well.
Old 5th August 2014, 08:32 AM   #4
blu_glo is offline blu_glo  England
blu_glo's Avatar
How is your power supply configured I notice you have one transformer for the power amps how many windings, rectifiers etc etc are you using??
Old 5th August 2014, 09:39 AM   #5
With the input disconnected you cannot hear any audio.
Hum in this situation is hardly a distraction.
You ONLY listen to audio with the input CONNECTED.
If there is no hum when the input is connected to the powered Source then you have no problem !
regards Andrew T.
Old 5th August 2014, 11:06 AM   #6
the transformer windings I don't know, but its cast in and in a metal cup, 225VA, 22V secondary.
The power supply has 4 diodes TO-247 HFA, 4 22uF capacitors in parallel. Then there are 4 resistors before the main capacitors. The filter caps are 4x 10 000uF and 4x 470uF and if I remember right 4 x 2.2uF
@AndrewT: so I don't have to worry about the amplifier PCBs, just get the Groundloops sorted? Small relief. Maybe I should make the supply cables to the crossover twisted and connect its ground to the star point next to the power in on the bottom right of the amp picture
Old 8th August 2014, 10:35 PM   #7
I drew it up, I suppose its the grounding, nothing else
Old 10th August 2014, 10:15 AM   #8
thats how its should be, if someone is reading:
remove some of the copper, so the power supply's star point is at the central tap of the transformer.
then connect everything to the star point.
thanks, David!
will post when I am done rewiring
Old 10th August 2014, 03:33 PM   #9
Speedskater's Avatar
The AC power SG/PE ground connects to the chassis at the power cord entrance.
The star-point Main Audio Ground connects to the chassis near the input signal jacks.
Kevin
Old 11th August 2014, 12:08 AM   #10
they are pretty close to each other, would not make much difference. Anything will be better than it is now...
reducing hum in SET amps pjpoes Tubes / Valves 8 2nd May 2007 12:32 AM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
PCB for TDA7560 and DIY AMPS Warheads Chip Amps 0 19th March 2006 08:40 PM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
A/B/Y and hum in guitar amps travis Instruments and Amps 7 14th July 2003 03:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
