Auxiliary Amplifier Application Circuit - diyAudio
Old 27th July 2014, 02:18 PM   #1
Default Auxiliary Amplifier Application Circuit
TI's LM chips seem to have both a Typical Application Circuit and an Auxiliary Amplifier Application Circuit shown in the datasheet.
After searching, I can find references to people using either of the circuits, but nothing specifically illustrating the reason for the differences in the circuits.
I can speculate as to the differences, but I thought it would be appropriate for someone more knowledgeable to outline this, as I'm sure it comes up when other novice folks are thinking about making their own design.
Old 28th July 2014, 02:37 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Please post some specific example
Old 28th July 2014, 06:42 PM   #3
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Typical application has minimal amount of components and sometimes even missing few..
But auxiliary amplifier application circuit has all and even extra for maximum performance.
Old 29th July 2014, 11:19 AM   #4
Auxiliary?
do you mean: single supply application?
regards Andrew T.
Old 29th July 2014, 07:11 PM   #5
Mihkus's Avatar
Nope. Check LM1876 datasheet...
Old 30th July 2014, 08:42 AM   #6
blu_glo is offline blu_glo  England
blu_glo's Avatar
May I suggest that you use the "auxiliary" circuit as it contains the best component setup to get you working with minimal fuss it's what I used in my chip amp circuits. Ci could be 47uf non polarised electrolytic for even better bass response. ...
Old 30th July 2014, 04:32 PM   #7
What's that RL circuit at output all about? Not like other Zobels I've seen.
Old 30th July 2014, 04:37 PM   #8
Mooly's Avatar
Adding an inductor in series with the output is common practice on many amps, indeed some would go as far as to say its an essential component. Its function is to isolate the amplifier output from purely capacitive loading which (on many amplifiers) can provoke destructive instability. The resistor damps any ringing that appears when squarewave testing amps.
Installing and using LTspice. From beginner to advanced.
Old 30th July 2014, 04:44 PM   #9
blu_glo's Avatar
LOL I just noticed it says its a 0.7uF, surely they mean uH?!
indeed, as Mr. Mooley suggests it is normal safety practice to include the RL network.
Rsn must be high power carbon or film type 2W or greater, NOT wirewound of any form....
Old 30th July 2014, 05:21 PM   #10
Henries, Farads, whatever .
So would this mitigate the need for Zobel?
I was going to say something about transient time, but it looks like that would be on the order of less than 1 uS.
Echo application circuit JO12 Chip Amps 2 17th September 2011 06:42 PM
Need comments on Semlab LMOS application Circuit Magna Solid State 1 8th February 2010 02:56 PM
Tapping Car battery as voltage source for auxiliary amplifier osu1177 Car Audio 10 19th December 2006 01:53 AM
problem with lm 3886 application circuit gothmog42 Chip Amps 19 3rd October 2006 06:06 PM
Is a crossover circuit really needed for this sound reinforcement application tspringer99 Multi-Way 17 24th January 2006 03:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
