how to test HCF4052BE - diyAudio
Old 14th June 2014, 06:20 PM   #1
leosep is offline leosep  ominican Republic
Default how to test HCF4052BE
Do you know how to to test the HCF4052BE ic? My amp isnt working any more.
Old 16th June 2014, 04:20 AM   #2
Your country name... is it correct.
If it is available locally, easiest will be to replace it. It is very cheap.
Why do you suspect this IC. It is mostly used as a signal selector(it works like a switch) in the circuit.
What is the name and model of the amp?
Do you have a DMM?
Gajanan Phadte
Old 16th June 2014, 05:47 AM   #3
Hi, yes im from Dominican Republic.
The amplifier is an old 'pro master usa' with no model name, looks like a home teather receiver.
I think is the IC because i dont see blown caps or condensers, im not sure, im not a professional. The amp turns on and everything, but no sound, no hiss, or hum. The eq screen where you see the bars up and down when playing, is not flat, the bars are up each one with different heights static, but there is no sound coming out of the speakers.
Old 16th June 2014, 06:26 AM   #4
KatieandDad's Avatar
Has the IC got Vcc ?
Old 16th June 2014, 07:29 AM   #5
Default Check across pins 8-16
Put a meter across 8 and 16, you should see a DC voltage between 5V and 15V.
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 10:20 AM
Jitter Test Signal (J-test Signal) with MATLAB merlijnv Digital Source 40 6th May 2013 04:36 AM
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
Copyright ©1999-2017 diyAudio
