My_Ref Fremen Edition - Collaborative DC-Servo design
Old 6th June 2014, 05:31 PM   #21
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by KSTR View Post
Let's run through the current version to check how a manual offset trim would be feasible.
Hi Klaus,
your post is invaluable, thanks
Some time to digest it is needed...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 6th June 2014, 07:53 PM   #22
KSTR is offline KSTR  Germany
KSTR's Avatar
Well, I would think the main question is : do we actually need a servo, other than for a design excersise (which is fine, of course). I mean, did anybody ever have more than 20mV or so of offset?
Old 6th June 2014, 11:43 PM   #23
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
But we don't have matched input resistances, one leg is 103k (R12+R13) while the other is 12k (R7). That alone could give a lot of current offset.
Input voltage at the 12k leg is 12k*500nA=6mV and input voltage at the 103k leg is 103k*500nA=51.5mV(!!) which results in an additional voltage offset of 45.5mV. And that is with zero offset current spec.
We could reduce R13 to 10k and that would match and lower source resistances as seen by the chip, any remaining offset would be convenient to trim out then. Any preamp (except exotic "passive" pre's with larger than 10k pots) should be happy to drive a 10k load.
If it was decided to try to balance input impedance, you could also increase the other leg (R7 + R10), for example, we could use a 100k for R7 and 3.3k for R10 and that would balance impedances. It would also bring C9, if needed, down to 26 uF with the same corner frequency, almost film territory.
Likely, this would be easiest somewhere in between for both legs, as long as they were balanced.
Old 6th June 2014, 11:58 PM   #24
Reality first!
Since C9 is present no one had, from what I know, more than 10-15mV of offset, most between 5 and 10mV.
So the servo is not necessary but is needed to remove C9.
That cap has a great effect on sound and the best caps in such position, Black Gates, are no longer available.
Also it's a great opportunity to learn something on DC servos.
Regarding your previous, wonderful and informative post... I'll try to summarize, please correct me if I misunderstood:
  • the trimmer can deal with LM318's intrinsic DC offset
  • the DC offset is dominated by the bias currents generated one and the actual design is pretty unbalanced in this regard
  • So C9 or a DC servo is still needed even if we trim LM318's DC offset.
  • a 120-150mV pull range for the DC servo should be more than adequate
Originally Posted by ClaveFremen View Post
According Cordell the capacitor in the post filter would be critical for sound quality and the goal is to remove as much as possible this problem.
Absolutely, but with a so low Fc (0.16Hz) how much AC would pass past the DC Servo? Isn't filtered enough?
Andrew, one nice thing about the double opamp Cordell's approach is that we can do active post filtering:
My_Ref Fremen Edition - Collaborative DC-Servo design-cordell-jpg
Dario
Old 7th June 2014, 08:05 AM   #25
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Originally Posted by AndrewT View Post
...Do not "add" an inverting opamp to either the non-inverting or the inverting servo. Just feed into the appropriate feed in node.
It can be fitted with an output filter. I consider this last mandatory...
I concur with both of these - it's simple and elegant, minimizes active parts, and can be optimized without too much difficulty.
Of course, the offset trim of the LM318 is even simpler, if there's not much ripple feedthrough from the opamp supply rail to the trim terminals (which are internally connected to the collectors of the LM318 LTP, and very much in the audio path, IIRC).
Old 8th June 2014, 10:01 PM   #26
lehmanhill's Avatar
Default An interesting experiment
OK, I was curious.
I took one channel of my FE RC amp, disconnected the speaker, shorted the input, and measured the voltage offset at the output. Then, I simply added a jumper wire to bypass the capacitor at C9. If Klaus' description is correct, we should see a jump in DC output offset.
Results
w/o C9 jumper - DC offset = 0.6 mV
with C9 jumper - DC offset = 20 mV
So I think we can say that C9 is killing a significant amount of offset. By the way, the offset was drifting, especially with the jumper. I'm not sure if that advocates for an active DC servo or if the pin 1 and 5 offset trim with a potentiometer would be enough.
I am also curious about the effect of a balanced input impedance. A very interesting design exercise all around.
Jac
Old 9th June 2014, 07:58 AM   #27
Reality first!
Really interesting Jac.
20mV is not that high, too; there are Gainclones with higher DC-Offset.
BTW we want less than 10mV so C9 or a DC-Servo are still needed.
Dario
Old 9th June 2014, 08:15 AM   #28
R.I.P.
the removal of the DC blocking capacitor then presents the input transistors with unbalanced source "resistance".
This unbalanced source resistance leads to increased sensitivity to temperatures effects and thus drifting with temperature.
Fortunately the input transistors inside the opamp will have a slow temperature error.
A slow acting DC servo will apply adequately fast correction to maintain a lowish to very low output offset.
regards Andrew T.
Old 9th June 2014, 08:18 AM   #29
R.I.P.
.............20mV is not that high, too; there are Gainclones with higher DC-Offset...............
there are many badly designed or badly assembled chipamp power amplifiers, where the builder/designer forgets that +-2mVdc is an achievable offset target without any special procedures.
Lehman confirms with this result:
regards Andrew T.
Old 9th June 2014, 09:14 AM   #30
spinwell is offline spinwell  Italy
Hello,
first of all, let me thank Dario and all the people involved in this thread: to add a DC servo to the My_ref FE is another excellent idea!
About the input impedances at the LM318, you all may remember that every component in the Mauro's design is carefully thought and I do think that the "unbalance" in the input impedances was made on purpose.
Second, still someone is writing about a change of the LM318. Again, please remember that the My_ref amplifier is a very sophisticated design where there is a strong use of feedback concept, phases balance, etc and that most concepts are tuned around the LM318. Change op-amp would mean to change almost all the components values, at least.
Third, the my_ref evolution had a DC servo (I'm sure that all of you know this). A simplified scheme was published on "costruire Hifi" n.116 (an Italian Hifi DIY magazine). I wonder if it is possible to publish here just the scheme. Dario, what do you think? It may help a lot.
my three cents,
Daniele
My_Ref Fremen Edition - Collaborative DC-Servo designHide this!Advertise here!
My_Ref Fremen Edition - Build thread and tutorial ClaveFremen Chip Amps 3911 17th June 2018 01:57 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition GB (Second run) ClaveFremen Group Buys 53 6th September 2015 01:19 PM
My_Ref Fremen Edition GB (interest for a third run) ClaveFremen Group Buys 107 12th January 2014 11:12 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
