My_Ref Fremen Edition - Collaborative DC-Servo design
Old 17th June 2014, 10:36 PM   #121
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Simulation of the above schematic. Close to zero audio signal at the servo input. It takes 90 seconds to reach zero offset. Could this be correct?
Regards Mark.
Old 17th June 2014, 10:55 PM   #122
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Wow, Mark.. it seem to work too good to be true...
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 20th June 2014, 05:15 AM   #123
geraldfryjr is offline geraldfryjr  United States
I just found a circuit that you may find of interest on page 10 of this document,
http://www.ti.com/lit/ds/symlink/lme49610.pdf
It is basically the same concept only it is using a LME49610 as an output buffer for only +/-250ma.
FWIW
jer
Old 9th August 2014, 08:20 PM   #124
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally Posted by spinwell View Post
Hello,
one crazy idea: is there any experience of using of a capacitance multiplier in the audio signal path? It could be used instead of the branch C9-R10.
it is equivalent to the cap, thus not as much effective as a servo could be, but it's definitely a quite interesting idea! [emoji106]
Of course it's impossible to say in advance whether it would be better or worse than just a plain cap, especially sound wise.
A similar approach could be to remove C9 and use a gyrator (a virtual inductor, of large value) in parallel with the global feedback resistor (same effect: bringing down to unity the gain at DC).
Could be worth trying both.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 9th August 2014, 08:37 PM   #125
UnixMan's Avatar
Back to the servo, the more I think about it the more I believe that the best place to inject the integrator output is between the 318 and the 3886, on one of the two inputs of the Howland Current Pump.
That would require much more (DC) gain by the integrator, but OTOH it would avoid interfering with the input differential.
Moreover, being in the middle of the overall NFB loop, any spurious signal (noise, etc) added by the servo will be drastically reduced by the NFB.
Though I wonder why Mauro have chosen a more conventional approach, acting on the input, for his own "Evolution" design...
Old 10th August 2014, 07:52 AM   #126
Wouldn't a signal (also DC) injected between the 318 and LM3886 be removed by NFB?
Regards Mark.
Old 10th August 2014, 10:41 AM   #127
AndrewT is online now AndrewT  Scotland
Is the DC servo positive feedback?
The inverting input sees the injected error. this is inverted to become negative at the amp output.
Then inverted again in the servo and injected into -IN.
equals +ve feedback ??
Have I got too many invertings?
regards Andrew T.
Old 10th August 2014, 12:53 PM   #128
UnixMan's Avatar
Yes. If the global NFB loop is active till DC (as it is here), the main NFB loop will try to restore any DC offset voltage present at input (times gain) at the output.
But the servo may be set up to have more gain (at DC) than the main loop, so that (at DC) it will "win".
In fact, by subtracting input village from the 3886, the servo will kill the "open loop" amp gain at DC (and subsonic frequencies).
No, of course it must be NFB.
The servo integrator must be inverting or non-inverting depending on the injection point (in this case, which "side" of the HCP).
(After all the servo is nothing else than another loop of negative feedback, acting only at near-zero frequencies, and having 0V instead of the input signal as its reference or "input" so to speak).
Old 10th August 2014, 01:27 PM   #129
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Interesting. I'm not familiar with a gyrator. Could you provide an example of point us to information on the gyrator?
Thanks in advance.
Old 10th August 2014, 03:08 PM   #130
bcmbob is offline bcmbob  United States
Mr. Elliot's take and the Wikipedia - Wow!!
Bob M.
"Arrange Whatever Pieces Come Your Way."
My_Ref Fremen Edition - Collaborative DC-Servo designHide this!Advertise here!
My_Ref Fremen Edition - Build thread and tutorial ClaveFremen Chip Amps 3621 4th January 2018 07:46 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 07:21 PM
My_Ref Fremen Edition GB (Second run) ClaveFremen Group Buys 53 6th September 2015 02:19 PM
My_Ref Fremen Edition GB (interest for a third run) ClaveFremen Group Buys 107 13th January 2014 12:12 AM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
