Help with LM3886 amp
Old 1st June 2014, 11:48 AM   #11
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by Mr Onion View Post
I shorted the input and the voltage dropped to 0VAC
When I removed the short, it rose to a stable 1.5VAC
Turning the amp off and on again initially it was ~40VAC which quickly dropped to a stable 1.5VAC without the input shorted. Shorting the input gave 0VAC as before.
My DMM lowest ranges are 20VDC and 200VAC
the input cap should have a 100k to ground connected...
another option is a 50k pot to connect that input cap to,
that way you can mute the amp at turn on...
the other hum issue you are having can be due to layout and wiring....
this is how i did my gainclone...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 1st June 2014, 12:02 PM   #12
R.I.P.
R5 and R3 are both shown as 22k.
Why should he change one to 100k?
regards Andrew T.
Old 1st June 2014, 12:06 PM   #13
TonyTecson's Avatar
the input cap is hanging on one side, it must not be left open like that...
100k? not critical, other values are fine, just do not leave that cap hanging
on one side...
Old 1st June 2014, 12:11 PM   #14
Mr Onion is offline Mr Onion  United Kingdom
Thanks all. I'll take that board out and play with it tomorrow
Old 9th June 2014, 12:02 PM   #15
Thanks for all the pointers. I have re routed the cables and I am getting 0VAC at both outputs.
I'll tidy it all up later and make sure they all stay in place.
Thanks again.
Old 14th June 2014, 10:56 AM   #16
Its all measuring and sounding good now, thankyou all
Help with LM3886 ampHide this!Advertise here!
Chip Amp LM3886 stereo kit - built & ready to go cdoggy81 Swap Meet 8 24th February 2009 08:26 PM
Great AMP PCB for sale~LM1875T & LM3886 slowgay Swap Meet 2 16th February 2009 12:24 PM
LM3886 & Others Chip Amp Heatsink Clamp Solution Travis Clarke Chip Amps 7 18th October 2007 04:36 PM
LM3886 & snubberPS PCBs and maybe kits (UK/EU) jimbo1968 Vendor's Bazaar 0 9th December 2006 03:44 PM
