LM3886 Oscillation?
LM3886 Oscillation?
Old 18th June 2014, 11:50 AM   #71
Dinithm is offline Dinithm  Sri Lanka
option - 1
the best way to solve this,use one power supply circuit.
option - 2
if u whant to use two power supply circuit you should use two trasfomers.
option - 3
isolation amplifire
I never try this,I cannot say this is 100% working
but you can try if you whant.
Low Phase Noise Design: Isolation Amplifiers
http://www1.futureelectronics.com/do...%20BA3121N.pdf
XXXXXXXXX
Kenwood KACX810D Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
Old 18th June 2014, 04:25 PM   #72
kaos is offline kaos  United States
Maybe Iím rehashing the obvious, but are you absolutely sure you have the transformer wired exactly the same to both power supplies (nothing cross-wired)? If not you could short a winding through the bridges when the grounds are connected together.
Old 19th June 2014, 08:14 AM   #73
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by dhanigan View Post
If I put them on either PS in parallel, hum is gone.
Then do that. I actually suggested this a while back...
If you only have one transformer, the best way to wire it is to have one supply feeding both channels. If you had two transformers (or a transformer with four secondary windings) you could use two supply boards.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 19th June 2014, 09:41 PM   #74
dhanigan is offline dhanigan  United States
~Tom
Isn't the benefit of having separate PS to get better channel separation? I could go with 1 PS I suppose.
Allan from Chipamp.com called me yesterday 2 hours after I sent an email and is working with me to troubleshoot. Darn good customer service.
I suppose part of the reason I'm so relentless with this is that I'm still puzzled how WWWJD over at parts-express forum can have the exact same rig and no noise.
Old 19th June 2014, 10:32 PM   #75
tomchr's Avatar
The same argument can be said for having separate transformers, separate enclosures, separate mains circuits, etc. How much channel separation do you need? How much are you getting with one supply? How would the performance be if you used all the supply caps in one supply feeding two channels?
I see no reason it shouldn't work. My guess about the mismatch between diodes is a bit far fetched. You should be able to make it work with one transformer, two supply boards.
You could also set up a simulation in LTspice with two rectifier bridges, caps, and mismatched current loads. See if that provides any clues to what's going on.
~Tom
Old 19th June 2014, 11:48 PM   #76
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I find when using a floating mobile phone or mp3 player I need to earth the zero volt line of my amplifier.
The other point I have had problems with is making sure the flow of wires through the rectifier and smoothing is split between the input side and amp side.
If you mix these the charging impulses into the smoothing caps will modulate your zero volt line.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
LM3886 Oscillation?Hide this!Advertise here!
oscillation merkur Tubes / Valves 28 10th May 2006 12:19 AM
Oscillation raveenvijendren Solid State 15 18th December 2005 10:16 AM
Oscillation udip Solid State 5 31st January 2005 05:43 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
What is oscillation? jnxw2 Solid State 10 18th May 2003 11:31 PM
