LM3886 Spice Model done - diyAudio
Old 8th January 2004, 07:30 AM   #1
Gerry is offline Gerry  Germany
Gerry's Avatar
Default LM3886 Spice Model done
my first posting on this nice forum.
Since I couldn't find one I did a crude LM3886 spice model (without modelling mute).
It's done along those lines:
http://www.ecircuitcenter.com/OpMode...2/opmodel2.htm
The LM3886 specs are here:
http://www.national.com/ds/LM/LM3886.pdf
Since I am a novice with opamps I would be most grateful if someone could do a check on it.
* LM3886 OPAMP MACRO MODEL (INTERMEDIATE LEVEL)
* IN+ IN- OUT VCC VEE
.SUBCKT LM3886 1 2 81 101 102
Q1 5 1 7 NPN
Q2 6 2 8 NPN
RC1 101 5 377.99
RC2 101 6 377.99
RE1 7 4 357.99
RE2 8 4 357.99
I1 4 102 0.001
* OPEN-LOOP GAIN, FIRST POLE AND SLEW RATE
G1 100 10 6 5 0.002645552
RP1 10 100 37.8MEG
CP1 10 100 0.0000526316UF
*OUTPUT STAGE
EOUT 80 100 10 100 1
RO 80 81 100
* INTERNAL REFERENCE
RREF1 101 103 100K
RREF2 103 102 100K
EREF 100 0 103 0 1
R100 100 0 1MEG
.model NPN NPN(BF=50000)
.ENDS LM3886
Gerry
Old 10th January 2004, 07:00 AM   #2
Pedja is offline Pedja  Serbia
Gerry,
I will look at this more closely ASAP, but this is the AC response in the MicroCap (inverted mode, 220k/10k feedback network). Needs correction, obviously.
Thanks for sharing.
Pedja
Old 2nd November 2004, 05:47 AM   #3
Lazyworm's Avatar
Send a message via ICQ to Lazyworm
I'm not succeed to use this model in PSpice (Schematics), is there
any conversion I need to do before I can use it?
I opened it up in PSpice A/D but didnt succeed to get an output file from it.
Old 2nd November 2004, 12:20 PM   #4
Gerry's Avatar
Lazyworm,
No idea, I used LTspice.
In any case I would be grateful for a reality check of this model.
If I recall correctly I had some problems in non-inverted mode - cant recall exactly what they were.
Cheers.
Gerry
Old 2nd August 2010, 05:41 PM   #5
lineup is offline lineup  Sweden
lineup's Avatar
Opamp Model -* Level 2
Q1 5 1 7 NPN
Q2 6 2 8 NPN
RC1 101 5 377.99
RC2 101 6 377.99
RE1 7 4 357.99
RE2 8 4 357.99
I1 4 102 0.001
RP1 10 100 37.8MEG
*OUTPUT STAGE
RO 80 81 100
RREF1 101 103 100K
RREF2 103 102 100K
EREF 100 0 103 0 1
R100 100 0 1MEG
.ENDS LM3886
Gerry
I added this model to my MultiSim.
It worked right away!
Thanks Gerry
lineup
Old 24th February 2012, 08:19 AM   #6
This LM3886 works fine with Multisim?
Spice model LM3886 needed. charlleqi Chip Amps 5 27th December 2006 04:49 AM
SPICE model Prune Parts 6 16th October 2004 03:22 PM
Does anybody have an lm3886 SPICE model? Faber Chip Amps 0 14th July 2004 12:31 PM
Spice model doigtee Tubes / Valves 6 12th July 2003 11:42 AM
Spice model for LED? G Solid State 5 14th September 2002 03:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
